05-22-2022, 07:13 PM | #1 |
Rep 1,047
Common rub points and how to address them
I've recently had a chance to view a bunch of different modded e9x m3's and there was one thing that jumped out at me: Every single car seems to be rubbing in the exact same 3 places despite the wide variety of suspension/wheel/tire setups.
In this thread- we'll talk about each of those rub spots, and how to address them. Front Wheels : 1. Scrubbing the rear of the fender liner. This rub will be nearly identical on both sides. There is hard metal behind this spot, so massaging the fender liner is not possible. The fixes need to come from the wheel/tire setup, and will be either one of the below or a combination of the fixes below:
2. Rub on the bulge on the rear of the right fender liner: This rub only occurs on the right side of the car. The bulge is not present on the left side. Behind this bulge is the windshield wiper fluid reservoir. There is likely a small amount of manipulation you can do with the fender liner to add clearance either with a heat gun or trimming here. Fixes are the same for the above:
Rear Wheels 1. Rubbing on the fender liner bulge where the fender meets the bumper: A few things to note. This nub protrudes more on the left side of the car than the right side and this is NORMAL. Every single car I checked was like this. This also means you may only notice rub on the left side tire and not the right side. Fixes are simple:
Observed a ton of cars taking this mitigation successfully. Seems to be more common than I thought. Final thoughts and warnings: It's quite odd that the same 3 spots seem to impact most cars. I had assumed that different wheel/tire/suspension setups would have had slightly different rub locations, but that just doesn't seem to be the case Lastly- BEWARE THE PS4S tire! The PS4S tire has very square/wide shoulders which can cause rubbing when other tire models don't rub at all. So when someone says this wheel/tire/suspension setup doesn't rub, pay extra attention to what tire model they are running. I'm sure there are other less common rub spots out there- but these are the run away common ones. Hopefully this information helps someone in the future. Last edited by drwankel; 05-22-2022 at 10:15 PM.. |
05-22-2022, 08:09 PM | #2 |
Lord Scrip
1816
Rep 3,014
Drives: 2011 M3 Coupe
I'm lowered and have them all. They worked themselves out without issue. Lol it actually looks like I proactively did something like neat dremel trimming
05-22-2022, 08:25 PM | #3 |
Rep 1,047
It's quite odd how ride height seemed to have very little to do with it. Symptoms were the same accross cars that were stock height or lowered. The common thread was wider wheels/tires, running spacers, or a combination of both.
In my car, at some point I had hit all 3 of these, and my car isnt lowered, but is a factory ZCP car there is a slight ride height drop. |
DrFerry6730.00 |
05-22-2022, 10:06 PM | #5 |
Rep 1,047
There is some truth to this. Some of the cars I looked at, the owners had taken the approach of let it rub, and the result wasn't as bad as I was expecting. Nobody had giant holes or anything of the like in their liners. Some were paper thin in places. The liner was still functional.
DrFerry6730.00 |
05-23-2022, 06:08 AM | #6 |
Rep 1,027
Pretty much my exact take on it Mine all show signs of rubbing and the fronts are totally worn through up front. Doesn't seem like you can avoid it if you're actually really driving the car hard.
Steve::::2012 AW E92::::IG - @sjs0433
DrFerry6730.00 |
06-10-2022, 07:28 AM | #8 |
Field Marshal
6730
Rep 1,829
Drives: '08 E92 M3
Sub'd, because the hive mind might have a few other solutions up its sleeve... Totally agree that smaller diameter tires - i.e. tires with diameters smaller than the original equipment sizes - fixes the rubbing issue. The Brand of tire can also fix it - due to tire shoulder shape (mold shape). But not all tires labelled with the exact same size have the same outer diameter(s) due to the T&RA / ETRTO / JATMA dimensional design "windows" chosen by their manufacturers. Hence, smaller O.D. is definitely better to fix rubbing. But how small is 'smaller' and enough? About 0.3 to 0.4 inches on the overall diameter in my experience. I tend to think that alignment also plays a role when combined with a different tire shape. Perhaps caster being the main contributing factor. Though that's only my speculation as I have no data to back that feeling up other than to say with increased castor most vehicles gain positive camber when turning the wheels (either dynamically or statically).
SilverSlug680.00 ///M Power-Belgium63516.50 |
06-10-2022, 10:58 AM | #9 |
Hey, where have you been all my life?
680
Rep 1,401
I didn't even know it was possible to adjust castor?
However this leads me to realize that perhaps just doing an alignment (especially after adding spacers or upsizing tires), may help with toe angles, and perhaps subsequently reduce a rubbing location. |
DrFerry6730.00 |
06-10-2022, 12:30 PM | #10 |
Rep 3,411
Need either race camber plates (with adjustable caster) or adjustable length thrust arms. One pulls from the top, other pulls/pushes from the bottom. I don't think you can adjust caster with OEM suspension components.
SilverSlug680.00 |
06-10-2022, 03:19 PM | #11 |
Rep 1,047
Correct, the only adjustment in the front when stock is Toe. You can get a small amount of extra camber by pulling the alignment pins, but that's it. No caster adjustment.
06-13-2022, 03:24 PM | #12 |
Rep 5,506
For the rear rubbing where the bumper meets the fender. The design is different on the sedan vs the coupe. The sedan will not only rub on the fender liner, it will also rub on the hard plastic piece right behind it. I see many people shave down the hard plastic. The coupe does not seem to have this issue.
Auto Detailing Enthusiast!
CSBM52722.50 |
09-11-2022, 12:36 PM | #13 |
Rep 36
This has been very frustrating for me. Recently purchased a squared 18x10.5 et22 setup and there’s a fair bit of rubbing in the front as shown in the pictures.
I’m tempted to ignore and continue driving this way till it has worn itself off. Although, how safe is it? Any solid advise? |
09-12-2022, 11:59 AM | #14 | |
Rep 1,047
Best option unfortunately is to move to a different wheel setup, or just live with the rubbing. |
09-12-2022, 11:42 PM | #15 | |
Rep 36
09-12-2022, 11:59 PM | #16 |
Rep 1,106
You need a narrower rim and tire to not rub at all. I'm running 18x9.5 et22 up front and 265/35/18 rub at around mid turn in both Continental DWS 06+ and PS4S. Full lock clears the mid-liner bump that is a common point of contact as shown above.
drwankel1049.00 |
09-14-2022, 12:39 AM | #17 | |
Rep 1,047
A 295/30/18 tire will rub in the front no matter what wheel you are running. Simply too wide. |
DrFerry6730.00 |
12-21-2022, 09:17 AM | #18 |
Rep 117
Does anyone have any data on the relative sizes of different brands.
I’ve read so many times, 275 30 19 ok a square set up, will not run, even with MP4S, but that doesn’t seem to be the case across the board. I’m inclined to leave the MP4S behind and get contisport7 because if the reviews but am concerned about making the situation worse. |
