BPM
      10-10-2009, 02:06 PM   #1
frankzlin79
frankzlin79's Avatar
Drives: 2018 M3
What to use to clean rust on brake rotors?
What is the best product to use to clean the rust off of the brake rotors and where can you buy it?
      10-10-2009, 03:28 PM   #2
Technic
Technic's Avatar
2288
Drives: 2021 i3S, 2024 i4 M50
First, let's take care of the cause of the rust: wrong type of wheel cleaner.
I use the BMW wheel cleaner and there is no rust in my brake discs. Now, if you use those Autozone/Pep Boys wheel cleaners -regradless of the brand- they will literally corrode your brake discs, causing that rust of yours.
I know, I've used those wheel cleaners with the same exact rust result...
      10-10-2009, 03:46 PM   #3
frankzlin79
Drives: 2018 M3
I use black magic. But I'll give the BMW wheel cleaner a try. Do you have a part number and approximate price?
      10-10-2009, 04:07 PM   #4
Technic
Technic's Avatar
2288
That's your rust cause.
Just ask the dealers parts department for an OEM bottle... I normally pay less than $7 per bottle when I buy a case (12 bottles).
      10-14-2009, 08:44 AM   #5
kmac1980
Drives: '19 540xi
brake pads?.....
After driving my car around the block the rotor rust is gone.
      10-14-2009, 11:13 AM   #6
foosh
foosh's Avatar
Drives: 2008 M3 E93
Huh? I only use car wash soap and water, and the rust appears within minutes.
The brake pads work fine to remove it.
      10-14-2009, 11:14 AM   #7
foosh
foosh's Avatar
Drives: 2008 M3 E93
The brake pads work fine to remove it, but I suppose if the car is primarily a museum piece you might need something special to clean it with.
      10-14-2009, 11:20 AM   #8
Technic
Technic's Avatar
2288
If you use any of those wheel cleaners you will know what I'm talking about...
      10-14-2009, 12:30 PM   #9
anthony @ eas
anthony @ eas's Avatar
Drives: R56 Cooper S
Originally Posted by kmac1980 View Post
brake pads?.....
+1
      10-14-2009, 12:32 PM   #10
doba_s
doba_s's Avatar
Drives: X7 l Cayenne l 997.2RS
wait, are you guys actually spraying it right on the rotors ?
      10-14-2009, 01:55 PM   #11
signes
signes's Avatar
Drives: 991 GT3 RS
Not sure I understand what you are saying here. Like Foosh said, plain water used during a wash will start to rust your rotors. One brake application later, its gone. I use P21S wheel cleaner but wouldn't use any of the "spray and rinse" crap.
To the OP, just go around the block and the surface rust will be gone.
      10-14-2009, 02:34 PM   #12
Technic
Technic's Avatar
2288
The kind of rust that I think the OP is talking about is much extensive that just the normal rotor surface rust after washing. The "cheap" wheel cleaners are really corrosive in my experience - one of the front calipers in my old E46 M3 was corroded to the point of replacement by the use of those cleaners in a couple of years. You know that these wheel cleaners corrode when right after cleaning the wheels you see brown residue all over the inside of the wheels after driving.
P21S and the BMW OEM wheel cleaner -they are supposed to be similar in formula from the same manufacturer- and just plain carwash liquid and water does not corrode at all and does not leave/produce any brown residue. So any rust that you can see in the rotors it is not only minimal but gone completely after the very first application of the brakes.
      10-14-2009, 03:37 PM   #13
doba_s
doba_s's Avatar
you should post some pictures - before/after ...
      10-14-2009, 06:02 PM   #14
M3twins
M3twins's Avatar
Drives: 2009 Le Mans Blue E92 M3 DCT
BMW will change out the rotors with your next brake service anyway, but the calipers are a different story. I'll use the BMW product to protect the calipers!
      10-21-2009, 08:39 PM   #15
NewM3driver
Drives: 2017 M3 ZCP
I have had more BMWs than I can count, and all the wheels have always pitted and corroded.
The M3 wheels come perfectly clean with just carwash soap and water. (no wheel cleaner) and look "new" after almost a year.
      10-21-2009, 10:19 PM   #16
d00t
Drives: M235i
I have to disagree. I would think he's talking about the thing layer of rust that forms after washing the wheels with any type of cleaner (maybe your specific BMW one not.. but I'm not going to argue that). The rust is extremely minor, and will be cured the first time you step on the brakes. I've NEVER had an issue in the many years I've been detailing cars.
      10-21-2009, 11:00 PM   #17
ScheerSpeed
ScheerSpeed's Avatar
Drives: '13 F30 Estoril M-Sport 335i
you dont need to use wheel cleaners every time you wash
      11-06-2009, 11:37 PM   #18
haze gray
haze gray's Avatar
Drives: 2009 M3 Coupe / 2011 X5
Drive it around the block and it's gone. Come on guy's, really is this worth a post?
      07-29-2010, 04:57 PM   #19
konnery
Drives: 2009 328i coupe
Its not the brake pads. It's the rotors.
See pic
      07-30-2010, 12:10 AM   #20
Trier Germany
Luxembourg
58
Drives: 2009 E-90 M3 space gray
Location: Deutschland KreisTrier auf Autobahn 64 & Tucson AZ
Drive your car it will gladly come off on it's own
