10-12-2020, 11:06 AM | #1 |
Rep 39
Actuators
Hi,
I hear about some possible renovation of throttle actuators. Somebody tell me there is a possibility to once yearly put a drop of oil on the axes w gears inside the actuators. That should enlarge lifetime of them. My M3 has now 60k miles, so actuators can die very soon and of course I'm not happy w replacement of both of them for 3k usd. Of course there are some gear kits for 100us, but you can't be sure if they will works. |
10-12-2020, 11:17 AM | #2 |
Rep 973
Drives: 2012 E92 M3 DCT ZCP
Just get rebuilt units from Rebuild in the UK: https://www.rebuild.org.uk/
Nowhere near $3K and the job isn't that difficult to DIY.
Ashley_rj31.00 |
10-12-2020, 11:41 AM | #3 |
Rep 3,331
Every piece of evidence about extending the life of the actuators seems to be mostly anecdotal at this rate. Assuming a normal mileage and ownership period, 1 set of actuators would likely last you the entire time you own the car. Rather than tearing the top of the engine apart just to stick a drop of lube I'd just wait until they need it and then get an aftermarket rebuilt unit for a few hundred dollars.
Since the part is generally sealed I don't see adding lubrication being a solution long term. If anything tearing the units apart over and over may introduce new issues.
Current: '20 X5, '18 M3 ZCP
Previous: '11 E90 335i, '11 E90 M3, '16 VW GTI, '15 M235i, '13 335i, '08 TL-S, '00 Corvette |
6ixSpd6011.50 |
10-12-2020, 01:15 PM | #5 |
Rep 10,591
I agree the $3k is a crazy price, but it’s probably what you pay if you take your car to a dealership.
New Continental VDO are about $600 each and identical to BMW. Rebuilt units from MPower in the US or Rebuild in the UK are about $350 each. I have seen the Continental VDO for closer to $500 before. In the time it would take to remove them, open them up, oil them, and put them back, you could replace them. Unless you have time to kill, are looking for a project, and want to do an experiment, don’t bother. If you insist, change the gears while you are in there. Some think that may help since the gears do wear over time. Some also think the problem is external and that you can just lube the throttle linkages periodically. Maybe with a long tube and good aim you could do that without having to pull the plenum? |
10-12-2020, 02:22 PM | #6 | |
Rep 3,331
If you wanted to drop a little oil on the linkages I suppose it couldn't hurt if you're already in there for a spark plug change or something else, but the entire weight of the throttle assembly seems like it would create far more friction than any dirt on the linkage connection. Again maybe would extend the life but by how much? By that definition dirt or oil buildup inside the throttle bodies probably creates more resistance than anything else.
10-12-2020, 03:40 PM | #7 |
Rep 39
ok, thanks. Unfortunately at Europe the parts are more expensive. But this VDO version can be there between 700-900 usd and OEM near to 1.200 us.
This VDO works well, same as OEM? I mean is necessary there to reset something, program it or is it only plug and play? |
10-12-2020, 06:48 PM | #8 | |
Rep 3,331
Like others posted if costs are a concern you can get a rebuilt kit. The two posted were between 450gbp and 450usd but you'd have to figure out which is cheapest for duty and shipping.
10-12-2020, 07:32 PM | #9 |
Lord Scrip
1812
Rep 3,012
Drives: 2011 M3 Coupe
$700 w/ tax OE new from ECS. They currently have a new one listed in the cosmetic dent/ding for $500. Since you don't see it and it's new why not?
10-12-2020, 09:56 PM | #10 |
Rep 121
Check out M Motors Sport remanufacture TAs. Great price/service and lifetime warranty. I just had my original TAs replaced with their.
2017 F15 X35i SAV, 2011 E93M E46,90 & 92 were gone but not forgotten!!! |
10-13-2020, 05:48 AM | #11 |
mTekMods
2129
Rep 2,892
10-13-2020, 08:53 AM | #13 | |
Rep 973
I just installed a rebuilt TA from MPower/Rebuild UK a few weeks ago and it is running great. Also comes with lifetime warranty. Lots of great testimonials for them: https://www.m3post.com/forums/showthread.php?t=1510324
10-13-2020, 10:27 AM | #14 |
Rep 42
i replaced both my actuators from mpowermotorsports.org
came out to $720 after i sent back my cores. hopefully never have to worry about replacing these ever again as they are rebuilt to outlive the car, and if i do, they have lifetime warranty. no need to buy new oem ones that are 2x the price and might go out again! |
10-14-2020, 02:45 AM | #15 |
Rep 96
Yep rebuild were fantastic and life time warranty. I would only do this option, best value by miles
2009 e90 M3 Harrop s/c
2006 golf GTI stage 1 2018 Triumph Street triple RS 1999 e36 M3 convertible-sold |
10-14-2020, 04:46 AM | #16 | |
Rep 7,090
These guys change gear to a better compotise material as well as sensitive electronics like the drivers, where after offer life time warranty. Tried to have a shop to do the job but got tired with their fiddling around and did it myself. Not a huge task. But, you don't need to do anything at all until you get the fail codes. |
10-15-2020, 02:03 PM | #18 | |
Rep 7,090
Loads on this subject if you take 5min and search around bud. |
10-15-2020, 05:22 PM | #19 |
Rep 39
clear, thanks, I found some link there about TA, very old. Well I read that, but stilll something isnt clear for me. If TA gears start to get worn you'll get a code and limp mode. If codes goes away when shutting of, the TA arent totally broken yet, right? I mean if you can start engine and not to be in limp mode, so then some cleaning as video shows is still possible or you need already replace the gears inside?
10-15-2020, 08:20 PM | #20 | |
Rep 465
