      07-19-2018, 04:57 PM   #1
gustavo0983
Drives: 2011 BMW E90 M3
Dinan under drive pulley A/C BELT
Can anyone tell me what is the size for Dinan D561-0002 A/C belt is? I am looking to buy an off the shelf replacement belt for it. thank you in advance.
      07-22-2018, 10:44 AM   #2
wyatth
Drives: E90 ZCP
Bump for you .. I’m looking at these pulleys and this would be good information to have.
      07-30-2018, 06:20 PM   #3
///Myers
Drives: 2012 M3 SSII DCT
Bump x2
      07-30-2018, 07:17 PM   #4
BayE30
Drives: 2011.75 E90 M3 ZCP
maybe contact Dinan?
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V]
      08-24-2018, 10:10 AM   #5
gustavo0983
I called and spoke with a couple of Dinan representatives, they would not give me that info, but they did try to sell me the Dinan A/C BELT.
      08-24-2018, 10:41 AM   #6
wyatth
Drives: E90 ZCP
I just received my kit in the mail (note their annual 10% off sale going on now). Which belt is it, the dual sided or single sided? I’ll measure it tonight.
      08-24-2018, 02:55 PM   #7
deansbimmer
deansbimmer's Avatar
3749
Drives: 2011 E93 M3
1988 BMW M3  [0.00]
2013 BMW M3  [0.00]
2011 X5M  [0.00]
2011 BMW M3  [0.00]
The D561-0002 A/C belt for the later version Underdrive kit is a double sided belt. I am not aware of any off the shelf available belts that cross reference to this size. A while ago I had a customer who popped his and needed this replacement belt asap. I looked through all my Gates, Bando, Goodyear, Dayco, Continental, and AC Delco catalogs and couldn't find one. I overnighted one from Dinan. Not worth it to spend hours chasing ghost part numbers.
Furthermore, this double sided serpentine belt is not one you're likely going to find stocked at any local store either. It's just not common. Much less trying to find an obscure length double sided belt.
It's only $47 from Dinan. It's not that much more than a new OEM belt.
      10-09-2021, 07:24 PM   #8
Scharbag
Scharbag's Avatar
Drives: 2011 E92 M3
2011 BMW E92 M3  [0.00]
So I ordered some belts from Dinan...
Seems like the water pump belt is a NAPA 6PK1421... NAPA? Really? And $32.08 for a NAPA belt? This is a $15 belt all day long. We will see if it fits but NAPA?
As for the Power Steering - A/C belt, it seems to be a 6DPK1070. This is available from ECS and Turner for $19.95. Good to know as Dinan charges $53.50.
Anyway, if anyone has a 2008-2013 M3 with the Dinan under-drive pulleys, this is your replacement part information.
Cheers,
rcracin1242.50
akkando5863.00
      10-10-2021, 12:45 AM   #9
SilverSlug
Hey, where have you been all my life?
SilverSlug's Avatar
Drives: 2011 M3 6MT
Just to clarify, Dinan offers two different pulley kits for the E9X M3.
Part# D560-0003 is for 2008-5/08 production date (single-sided power steering & AC belt)
Part# D560-0004 is for 6/08-2013 production date (double-sided power steering & AC belt)
      10-10-2021, 12:49 AM   #10
Scharbag
Scharbag's Avatar
Drives: 2011 E92 M3
Yup. That is why I listed 2008-2013.
      11-20-2021, 03:25 PM   #11
Idfkman
Idfkman's Avatar
Drives: F80 M3
Cheers,
Double checking to verify that the 6DPK1070 part number from ECS is the correct part number for the Power Steering/AC belt? Just snapped mine and wondering if it’s worth the risk of saving some bucks versus just ordering from Dinan.
      11-20-2021, 08:09 PM   #12
SilverSlug
SilverSlug's Avatar
Drives: 2011 M3 6MT
The two belts you need to complete this install are:
6pk1421 and 6dpk1070
I actually just finally installed mine today. Well worth it.
Idfkman473.00
      11-20-2021, 08:16 PM   #13
SilverSlug
SilverSlug's Avatar
Drives: 2011 M3 6MT
Install tips:
When sliding out the fan, be careful with that driver's side cooling line nozzle… It looks brittle af, like it can break off quite easily.
I didn't want to take it off and potentially introduce air into the cooling system, and can confirm it's possible to remove/install the fan to complete the install with that line in place.
So, loosen the expansion tank cap to release the pressure from the cooling system (if engine is warm), you'll be able to really flex the little hose to put less pressure on the nozzle. This will also relieve any pressure on the big coolant hose near the pulleys to slide the fan out.
Driver's side of the fan is held in place by a press clip, while the passenger side of fan is held by a torx screw.
The torx size for the pulley bolt is a T25 (have to work in blind since you can't see into it). Be careful not to knick the interior of the radiator when you're working in there, those radiator fins bend super easily.
Finally, when you're putting the first belt on, set it into place before re-installing the idler pulley, this makes it wayy easier then having to have to squeeze it in between and potentially putting a tear in the belt.
Idfkman473.00
      11-20-2021, 08:37 PM   #14
Idfkman
Idfkman's Avatar
Drives: F80 M3
Install tips:
Super helpful info! Both belts ordered so hopefully we can get her back up and running by next weekend.
10 E90 M3 /// Dinan Intake, X Pipe, Exhaust, Underdrive, 3.62 Diff, Coilovers, Alpine e85 Tune - sold
16 F80 M3 /// MaxPSI 4 Pin, DP, CP, SL Mid-Pipe, TMIC, KW HAS, EU5's, AB Performance Flex Tuned
      11-20-2021, 09:12 PM   #15
SilverSlug
SilverSlug's Avatar
Drives: 2011 M3 6MT
Lmk if you run into any questions on the install
Idfkman473.00
      12-15-2021, 10:12 PM   #16
Idfkman
Idfkman's Avatar
Drives: F80 M3
The accessory belt install with the Dinan under drive pulley a few weeks ago was super straight forward thanks to your tips.
I only ran into one hiccup which occurred while reinstalling the radiator fan. I broke the plastic tube coming out of the upper radiator hose that connects to the expansion tank which seemed inevitable to break while reinstalling the fan unless I removed that hose which I probably should have done in retrospect. Never the less I just needed to order a $20 dollar replacement hose and a bottle of BMW antifreeze to refill what spilled out and I was all set.
The alternator and water pump hose were a bit of a pain but was able to get the belt on with a pick tool. The power steering and AC belt went on without much struggle at all to my surprise.
      12-16-2021, 12:15 PM   #17
SilverSlug
SilverSlug's Avatar
Drives: 2011 M3 6MT
Nice, well done; all is well that ends well.
Given that some air may have been introduced into the cooling system with that nozzle break… Did you complete a burping procedure to assure any air has been removed?
