      07-30-2020, 01:54 PM   #1
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
Help: Fuel smell and drops from fuel line
Hi All
deansbimmer
amrazM
I am trying to R&R my coolant thermostat and I got to the fuel line on top of the thermostat housing. (1) I noticed the white clip is broken, so I plan to get a new one but more importantly (2) when I went to slightly move the fuel line I smelled fuel and saw a couple drop from this point in the fuel line in my picture below circled in lime green.
I am wondering if this is bad and I need to get a whole new fuel line or is this normal because I flexed the fuel line some came out? Or should fuel never leak out of that line?
Please help.
Thanks.
      07-30-2020, 02:37 PM   #2
roastbeef
roastbeef's Avatar
Definitely replace.
      01-21-2021, 04:55 PM   #3
kornykidd0
Drives: 2008 E90 M3
I just noticed something similar on the driver side when I was replacing my starter. Does it leak when the car is running? Mine does not spray or leak but when jerked around I can get a little. I’m worried about needing to replace it all as well.
      01-21-2021, 05:23 PM   #4
SAMM3Y
SAMM3Y's Avatar
3085
Drives: 2008 m3
You should start carrying a fire extinguisher JIC
9ers
      01-21-2021, 06:50 PM   #5
mapster37
mapster37's Avatar
Drives: F80
replace the line. you dont want to take any chances with a fuel leak...
      01-21-2021, 07:47 PM   #6
Ajolives
Ajolives's Avatar
922
Drives: E90 M3
2019 Audi SQ5  [0.00]
2008 BMW M3  [0.00]
It's only going to get worse after time, how much time is the question. Should replace ASAP.
      01-24-2021, 12:19 PM   #7
Helmsman
Helmsman's Avatar
Sweden
4464
Drives: 2011 AW E90 M3 ZCP
Felt a light fuel smell when I bent the line to replace the tstat. Put it back together, no issues since.
      02-03-2022, 11:39 AM   #8
waski
waski's Avatar
Poland
36
Drives: 335i
Look like i got same problem , do you guys replace fuel rails ?
      11-19-2022, 04:04 PM   #9
exVtekGuy
Drives: none yet
i faced the same problem when doing t-stat. is this common? does it require fuel rail replacement??
      10-30-2023, 11:22 PM   #10
ab987
Drives: X3M, M3, 335i
2008 BMW 335i  [9.00]
2020 BMW X3 M  [9.25]
2010 BMW M3  [9.00]
2016 Mini Cooper  [0.00]
Checking in here because mine did the same. No leak at all while the car is running or off with fuel pressure, just a few drops when I bent it upwards and can't seem to get it to happen again. Did you guys end up replacing yours?
'20 AW F97 X3M | '10 AW E90 M3 DCT | '08 Karmesinrot E93 335i 6MT -> RB Twos | FBO | Tuned by Ken@Wedge | 550i Clutch | Walbro 535 | M3 Control Arms | PS4S
