Go Back   M3Post - BMW M3 Forum > M3 (E90 / E92 / E93) > Regional Forums > Australia
      06-13-2021, 08:33 PM   #1
Fezza
Fezza's Avatar
Australia
149
Drives: '11 Japan Red E92 M3
SOLD: Turner Motorsport Aluminum Skid Plate
12 months old but like new - SOLD
  • 3/16” thick aluminium powder coated main plate and 1/8” thick aluminium powder coated side plates
  • 1018 powder coated steel tube support braces for maximum skid plate strength
  • Retains factory air duct for oil cooler
  • Maintains wheel liner mounting positions
  • Contains all necessary stainless mounting hardware and components (OE rubber trim from the vent will need transferred)
  • No modification necessary; easy to convert back to stock
Installation:
      06-15-2021, 11:21 PM   #2
Willaayc
Willaayc's Avatar
Australia
19
Drives: E92 M3 Harrop S/C
Would you ship this to Sydney?
      06-15-2021, 11:23 PM   #3
Fezza
Fezza's Avatar
Australia
149
sure can, $50 extra anywhere in Australia
      06-15-2021, 11:44 PM   #4
Willaayc
Willaayc's Avatar
Australia
19
great, let me check clearances with the Harrop kit cooler lines. Will come back to you shortly
      06-15-2021, 11:50 PM   #5
Fezza
Fezza's Avatar
Australia
149
I believe the only issue will be the driver side support bracket, so you'd have to install only the passenger side one, i.e. doing away with the below red circled bolts:
      06-16-2021, 01:19 AM   #6
FundedbyCrypto
Drives: M3 E90 Comp
Hey Fezza,
What have you decided to go to? I ended up getting a brand new OEM one and its really poorly made and is stupidly expensive for what it is.
      06-16-2021, 01:27 AM   #7
FundedbyCrypto
Drives: M3 E90 Comp
Originally Posted by FundedbyCrypto View Post
Hey Fezza,
Put it this way this one is superior in every way and is over $400 cheaper!
      06-16-2021, 01:58 AM   #8
Fezza
Fezza's Avatar
Australia
149
then sell your OEM one and buy this I went with the 1 piece mporium version.
      06-16-2021, 02:00 AM   #9
Willaayc
Willaayc's Avatar
Australia
19
Thanks for the heads up on the support bracket. Saved me some time trying to figure out if it'll fit. Would you know if using the original wire support will work on the driver side?
      06-16-2021, 02:03 AM   #10
Fezza
Fezza's Avatar
Australia
149
yes that's what some people have done (https://www.m3post.com/forums/showpo...1&postcount=18) but honestly there are so many screws holding it together it'll most likely hold just fine without the 2 bracket screws.
      06-30-2021, 05:11 AM   #11
StavrosV
StavrosV's Avatar
Australia
9
Drives: 2013 BMW E92 M3 pure
Wish I noticed this was available
