BPM
      09-06-2014, 03:10 PM   #1
gthberg
gthberg's Avatar
15
Drives: e90 M3 IB/FR
2009 e90 M3  [0.00]
2015 Range Rover Ev ...  [0.00]
1987 BMW M6  [0.00]
Snapped coolant bleed screw
Any brilliant ideas out there for removing half of the coolant expansion tank bleed screw? I was flushing the radiator today, and while I was doing the final bleed, the screw snapped in half (with hardly any torque, which is awesome)....should have seen the fountain of coolant spouting up in the air! So, I'll grab a new one, but I'm having a rough time getting the old one out, without any top to it. I'd like to avoid drilling it, so I don't get a bunch of plastic shavings in my expansion tank.
Thanks.
      09-06-2014, 03:23 PM   #2
tinman831
Drives: M3
Heat a screw driver and place on top of screw. Melt a slot into the top, let it cool and twist out?
      09-06-2014, 07:37 PM   #3
s85e90
Drives: black e90
If you have to drill it coat the bit in vaseline and you won't get chunks in the tank. They also make a brass replacement FYI.
      09-06-2014, 07:52 PM   #4
Devant
Drives: '11 M3
+1 on the brass fitting.
I think it is seriously annoying the amount of plastic they use in what is supposed to be a high end car. Plastic reservoir ok but plastic screw plugs..really? Nice job BMW
      09-06-2014, 08:38 PM   #5
Cbozz
Cbozz's Avatar
Drives: M3
I used a screw driver method..... +1
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      09-07-2014, 09:09 PM   #6
vastano
Drives: F15 X5
http://www.turnermotorsport.com/p-21...tion-list.aspx
      09-07-2014, 09:50 PM   #7
1MOREMOD
1MOREMOD's Avatar
Drives: Race car->
Good call
      09-08-2014, 09:32 AM   #8
W///
W///'s Avatar
5989
Drives: F87 M2C, E92 M3, E36 M3, Z4MR
Thanks.
Mine did the same thing. What I did that worked really well. Take a cutter/razor blade and start making straight lines, deep enough that you can use a flat head screw driver to back it out. Took me about 10-15 mins, but it worked well.
So the top of that left over part should look close to this:
Current: 19 F87 M2C / 08 E92 M3 / 07 E85 Z4M Roadster / 99 E36 M3
      09-28-2014, 06:55 PM   #9
dreamspeed
dreamspeed's Avatar
Drives: 6MT
Originally Posted by vastano
Does anyone have a link to a brass screw for the e92 m3? Those screws at turners doesn't fit the m3 according to the list
      09-28-2014, 08:49 PM   #10
edwinm3
edwinm3's Avatar
Drives: F82
Yes turner screw does fit the m3, follow this thread
http://www.m3post.com/forums/showthread.php?t=886184
Grigio Telesto M4, 6MT.
Coyote F-150
      09-28-2014, 08:59 PM   #11
dreamspeed
dreamspeed's Avatar
Drives: 6MT
Cool, thanks!
So it looks like BMW part number 11537793373 is for the E92 bleed screw and
17111712788 is the part number for the E46 bleed screw but they are both the same.
      09-28-2014, 09:20 PM   #12
edwinm3
edwinm3's Avatar
Drives: F82
Cool, thanks!
Glad I could help
Coyote F-150
      01-07-2018, 05:02 PM   #13
JsL
Drives: 2011 AW M3 ZCP
This happened to me while driving! I got the low coolant warning, pulled over and saw coolant spilled all over the engine bay. I was nervously watching my P3 guage coolant temp while driving back home.
The heated flathead screw driver method works. Here's what I did.
1. Dry off the top of the snapped screw.
2. Turn the stove on and leave the flathead screwdriver tip on the flame for 90 each side. I just picked 90 seconds as I didn't want to melt the handle.
3. Walk to the car, presuming the hood is already open of course, center the screwdriver on top of the screw and push the screwdriver in with a little force downward. You should hear a little sizzle. I left it on there for 10 seconds after the sizzle stopped.
4. Repeat step 2 and 3. Resist any temptation to unscrew it while it's hot, that would be counter productive.
5. Wait 3 mins.
6. Unscrew using the notch you just created.
If you're in a pinch to get a replacement bleeder screw, your local parts shop may have the Dorman brand in stock. I used it and it fits fine. $5 for two screws with gasket. I'll be changing mine every 60k miles as preventive maintenance from now on.
      01-01-2019, 04:54 PM   #14
cmyE93M3
cmyE93M3's Avatar
Drives: E93 M3
Sorry to bump an older thread, but thank you for the above advice, my bleeder screw head snapped today during some routine maintenance I was doing and this method worked like a charm.
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019)
2019 Lexus IS300 (lasted 3 months)
2020 Toyota 4Runner TRD (fun truck)
2014 Tesla Model S P85 (wicked car)
2011.5 E92 M3 | Space Grey | ADV.1?s
      03-28-2021, 07:40 PM   #15
Ximian
Ximian's Avatar
2021 BMW M3  [0.00]
2011 BMW M3  [0.00]
I tried the method of heating up a screw driver but that was taking too long. I used a rubber mallet to hammer in the screw driver and that came out easily.
The Dorman screws are junk, snapped off very easily.
      06-06-2021, 06:23 PM   #16
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Great thread! The heated screwdriver method worked for me as well. Heading to the dealer tomorrow to pick up two new bleeder screws. I would pick up a brass on from Turner, but they appear to be discontinued. Any idea if someone still makes them?
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Black M3 Vert
      06-06-2021, 06:36 PM   #17
derbo
Derbo Tuning
derbo's Avatar
Drives: 2011 BMW M3 Sedan
FWIW,
BMW TIS doesn't mention ever using the bleeder screw on the S65. If leaving the cap off is sufficient to BMW, it's good enough for me to avoid touching that bleeder screw.
      06-08-2021, 11:05 AM   #18
amrazM
mTekMods
Drives: like a granny.
Send a message via AIM to amrazM
Originally Posted by derbo View Post
FWIW,
It doesnt but when the system is completely empty and you dont want to run the car its easiest to crack the screw then fill the system, the bleeder screw actually lets alot of air escape and allows coolant to flow.
2011 Frozen Black/Fox Red E90 M3
NBT Evo, Digital PSW, Dinmann CF, M PERF E Brake.
KW CS 2W, Hotchkits F/R, Solid SF/Diff.
GPower SKIICS, ARH Headers, MS GT2
E90 M3 by Amraz Mohammed,
      06-08-2021, 11:27 AM   #19
4130
Drives: 2011 E90 M3 LeMans Blue
I bought this one recently and it fit well: https://www.amazon.com/AUTOHAUX-Radi.../dp/B07ZQCCJNR
DRLane1798.50
      06-14-2021, 06:40 AM   #20
bake
bake's Avatar
I actually bought the same. Amazon said i doesn't fit my 2013 but it does. Better option than the OEM plastic one.
Bake
      06-14-2021, 11:12 AM   #21
Johnr3524
Drives: 2018 X5
I'm slowly lining up parts to flush my system. I haven't done it before on this car. Is this screw https://www.amazon.com/AUTOHAUX-Radi.../dp/B07ZQCCJNR for both the top bleeder screw and the drain plug? Or is the drain not plastic?
      06-14-2021, 12:37 PM   #22
Johnr3524
Drives: 2018 X5
I figured it out. The drain plug is, of course, different. FCP Euro I go...
Search this Thread:
Advanced Search
Copyright ©2000 - 2021, vBulletin Solutions Inc.
