09-09-2013, 10:25 AM | #1 |
White Shark
88
Rep 919
Help. Clunk sound from transmission when letting off gas in gear 1-2
I hear a clunk noise from the transmission area when I let off the gas in first gear. For example, I'm driving in 1st gear while in a parking lot and the RPM is at 3k, then I let go of the gas and and RPM drops and I hear a clunk noise. This also happens in 2nd too. I also hear it when getting off from 1st gear.
Its been getting worst lately and i been hearing it more and more. Any clues on what it might be? had a BMW mechanic hear it and couldn't tell what it was.
ESS | Challenge x-pipe | Akrapovic | Stoptech BBK (380/355) |Ohlins R&T | Dinan | Vorsteiner | Downforce USA | Varis Diffuser | Gintani | UUC | BMW Performance | Macht Schnell | Forgestar F14's SDC 19x9.5F 19x11R | 255.35 295.30
09-09-2013, 02:13 PM | #2 |
Rep 8,077
Drives: 11 E90 M3 Individual
I would guess a driveline mount or flex disk.
2018 F30 320iX Melbourne Red
09-21-2014, 08:55 AM | #5 |
White Shark
88
Rep 919
click on the pdf i attached it explains what you have to do if you have such a sound. its was something to do with the input flange but it might not be the case in all situation. The pdf file explains the service needed.
M3clicking.pdf
09-21-2014, 06:33 PM | #6 |
Rep 10,651
You wouldn't by any chance have the repair procedure referenced in that PDF,
"RA 33 01 021" I would really like to see the details for reinstalling the diff input flange. |
09-21-2014, 08:48 PM | #7 |
Rep 40
I have similar noise in my car (DCT)
it sounds more like a clunk, like something is getting loose it happens when getting on and off the gas, as OP says, RPM drops and hear the noise, same to me so could it be clutch pressure plate dis/engaging noise? |
09-29-2014, 03:54 PM | #8 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Check your rear diff bolts as well, sometimes it can sound like the clunk is coming from further forward. Rear diff bolts getting play from the squishy mounts and snapping is a know issue so be worth looking at.
07-08-2016, 04:22 AM | #9 |
Rep 147
I have this problem too, any solution? So the problem from transmission or LSD? Is this just inconvenience sound or it will broke my car?
07-08-2016, 04:57 AM | #10 |
Rep 147
Is this article the answer?
