09-02-2020, 10:19 PM | #1 |
Rep 2,492
Water/Oil temps - high threshold for AIM dash
Does anyone have input on separate high water and oil temperature thresholds? I am setting up my AIM dash alarm configurations and now have separate oil and water temps.
I was going to do 250-260 oil, 150? Water. Not sure what these cars run at when lapping. Comparing to my vette temps. Thanks in advance!
2010 E92 M3 DCT
09-02-2020, 11:43 PM | #2 |
Rep 1,591
Are you asking what temps you should have the alarms trigger at? If that's the case you'll probably be looking around 275 for oil and ~230 for water.
Oil temps of 250 are fairly typical when tracking hard and nothing to worry about. Anything above 275 I'd start to worry and want to back off. Perhaps like 270 and 220-225 for the alarms to trigger are good starting points. |
ThunderMoose745.50 Move Over1256.50 |
09-03-2020, 04:57 AM | #3 | |
Rep 2,492
2010 E92 M3 DCT
tsk941522.00 |
09-03-2020, 08:21 AM | #4 |
Stop the hate, get a V8
3850
Rep 8,625
I would set the warnings to 275 on oil and 230 for water.
Remember that you are measuring the temperature at the sensor location. For example, the oil temp in the bearings is much higher than 275 even when the gauge shows 275.
Past: 2011.5 M3 sedan ZCP |
09-03-2020, 10:04 PM | #5 |
DSC Off!
304
Rep 718
I just looked back on my last event when I got the first yellow warning at close to 280 so I'd agree with setting a warning at 275 for oil temp. Water was around 220.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
09-04-2020, 09:33 AM | #6 |
3850
Rep 8,625
Maybe the best approach would be to look at your historical data, find the average for each of those across an entire day, then set the warning at 5% above?
09-04-2020, 09:34 AM | #7 |
Rep 2,492
Just looking for a starting point, I don't have any historical data on this car. Only my camaro
2010 E92 M3 DCT
09-04-2020, 09:46 AM | #8 |
3850
Rep 8,625
Then I'd use the 275 and 220/230 numbers as many have suggested. Check the data after your first session and see if that's appropriate. You can always change it later. The place you don't want to be is to have the warning set at a place where you might quickly touch it for a half-second each lap, which distracts you.
09-04-2020, 10:00 AM | #9 | |
Rep 2,492
2010 E92 M3 DCT
09-04-2020, 09:03 PM | #10 |
Rep 2,869
I programmed the AiM as follow:
Warning - Oil Temp below 200 (yellow led) Good - 200-240 (green light until button pressed) Warning - 240-250 yellow Critical - greater than 250 All above using same LED on the GS display. I have the do88 and historical data shows below 250 temps I have similar for water temp and oil pressure using other LED (I have 4 to play with) |
09-04-2020, 09:05 PM | #11 | |
Rep 3,408
09-04-2020, 09:12 PM | #12 | ||
Rep 2,869
Move Over1256.50 |
09-06-2020, 09:59 PM | #13 |
Derbo Tuning
3609
Rep 3,022
I was seeing my oil temps at about 265F this past saturday during 95F ambient temps.
IG:ruhrohz_m3
