03-28-2019, 12:27 AM | #1 |
///Majestic
1860
Rep 2,092
Differential clunk under sudden acceleration.
I tried searching before posting but could not find an answer.
When I do a sudden hard accleration I get a kick in the back, a loud clunk, just one initial clunk and that is all. If I preload first and then floor it I get no clunk, it's only when I do a sudden hard acceleration. Is this normal? Any thoughts would be appreciated. |
03-28-2019, 01:29 AM | #2 |
mTekMods
2139
Rep 2,899
Diff. Bushings.
Seems obvious no? If you preload the diff the bushings are already loaded and the diff has already moved, suddenly acceleration is causing the diff to jump. I suggest You get it checked out ASAP before you damage something. You probably could mount a go pro somewhere underneath to see if it is in fact the diff moving. |
Siajoon1859.50 |
03-28-2019, 09:15 AM | #3 |
///Majestic
1860
Rep 2,092
I suppose that makes sense, Maybe I should just try getting the diff bushings replaced regardless.
Only reason I haven't is because I was told they last atleast until 100k. Currently at 68k. |
03-28-2019, 09:33 AM | #4 | |
General
63318
Rep 24,656
Siajoon1859.50 |
03-28-2019, 09:36 AM | #5 |
Rep 5
I replaced my diff bushings with Poly and did solid aluminum subframe bushings and I still have a noticeable clunk coming from the rear. ( Driveshaft and guibo looked fine, but I know those are likely my next areas of concern or the diff itself)
03-28-2019, 01:04 PM | #7 |
Rep 1,881
lol took yer eyes off the road for 1 second at 0:45 and almost lost it.
03-28-2019, 01:17 PM | #8 |
///Majestic
1860
Rep 2,092
03-28-2019, 02:07 PM | #11 |
Rep 1,930
If you tap the throttle in high gear/low speed do you hear a clunk?
Most types of clunking is associated with the U-joint on its way out. Those are not serviceable and need a driveshaft. |
03-28-2019, 02:22 PM | #12 |
///Majestic
1860
Rep 2,092
No, usually lower gear higher rpms when I put the motor on its toes, and then I left off and then sudden accel it knocks
03-28-2019, 02:27 PM | #13 |
Rep 1,930
03-28-2019, 02:32 PM | #14 |
///Majestic
1860
Rep 2,092
2,000 miles ago when I replaced my rod bearings at MRF...
03-28-2019, 07:39 PM | #15 |
Driver
2692
Rep 2,714
Well if you want to rule out your diff bolts and bushings just slide your legs under the rear of the car and press on the diff from different angles. It will be extremely obvious if you have a broken diff bolt or bushing.
I would at least check that before driving the car again. If it is a broken bolt/bushing you can destroy the mounting portions of your subframe if you keep slamming the diff around. |
Siajoon1859.50 |
03-28-2019, 08:23 PM | #17 |
///Majestic
1860
Rep 2,092
03-28-2019, 08:24 PM | #18 | |
///Majestic
1860
Rep 2,092
03-28-2019, 08:59 PM | #21 |
///Majestic
1860
Rep 2,092
03-28-2019, 09:01 PM | #22 |
///Majestic
1860
Rep 2,092
I'm taking it to MRF possibly tomorow to get his analysis on the situation. Hoping it's nothing crazy as I just dropped some pretty pennies for actuators and bearings lol
