01-10-2019, 12:53 PM | #1 |
Rep 3,001
Powersteering Tank Upgrade?
Hey guys what Power Steering tank upgrade are you guys running?
I'm tired of the OEM one pissing through the cap after some spirited driving. What's the most cost-effective one out there? I've upgraded my DCT to the CSF cooler, thinking of getting the power steering rad upgrade also. Thanks!
INSTAGRAM: GORDON.M3
01-10-2019, 10:40 PM | #5 |
Rep 2,824
Isn’t there an updated PN or a part from another model that is PnP, cheap, and better? I forget now, will look it up again and report back.
If it’s minimal overflow, you can also just get a reservoir sock (sweatband) and wrap the cap. |
01-10-2019, 11:18 PM | #6 |
Rep 3,001
I think the bimmerworld tank has been out of stock for a long time...
01-11-2019, 12:55 PM | #8 |
Rep 2,824
^ Yup that's it. Think it's shared with some F-chassis cars as well.
Cheap, OEM, PnP, seems to solve the issue. https://www.m3post.com/forums/showth...ring+reservoir |
01-11-2019, 03:23 PM | #9 | |
Rep 3,001
ItsGary1457.50 |
01-16-2019, 01:08 AM | #12 |
Rep 3,001
hmmm that sucks.... welp... I hope its better than the original one?
01-16-2019, 02:47 AM | #13 |
Rep 957
01-16-2019, 10:35 AM | #14 |
Rep 303
Sooo the bimmerworld PS res is the cheapest/best option to fix the problem? About to start tracking my car and really don't want PS fluid all over the place...
Matt@AUTOcouture4166.00 |
01-16-2019, 04:36 PM | #16 | |
mTekMods
2142
Rep 2,901
I’m running the 1M tank in my car and I ran The tail of the dragon and blue ridge parkway pretty hard and the fluid stayed inside the tank.
01-16-2019, 05:11 PM | #17 |
Rep 5,506
There is another solution to the problem - replace the power steering cooler. The problem with the fluid overflowing is because it is overheating. If you update the cooler, it should not have the overflow issue. CSF has a upgraded powersteering cooler:
https://www.ecstuning.com/b-csf-part...oler/8041~csf/
Auto Detailing Enthusiast!
SAMM3Y3085.00 MilehighM3915.00 |
01-16-2019, 05:24 PM | #18 |
mTekMods
2142
Rep 2,901
Also to note, I run the 1M tank with a do88 ps cooler.
01-19-2019, 07:56 PM | #19 |
Rep 278
A lot of the install pics of the 1M reservoir use one adapter which is incorrect. The larger port is the supply and the smaller port on the reservoir is the return which is under pressure. It's the same relationship as the stock M3 reservoir. If only one adapter is used, the higher pressure return fluid will be sent through the supply port and shot up (at high rpm) at the inside of the reservoir cap which causes a little bit of fluid leakage. I run a 1M reservoir with the hoses on the correct ports and a do88 power steering cooler with zero issues.
Here are before and after pics of the 1M the reservoir hooked up incorrectly and the correctly: https://www.m3post.com/forums/showpo...0&postcount=60 Notice the turbulent fluid at idle with the hoses reversed versus the calm fluid with the hoses correctly installed. |
Makaveli7116.50 |
01-19-2019, 08:05 PM | #20 | |
Rep 278
SYT_Shadow11479.50 Makaveli7116.50 |
01-19-2019, 11:20 PM | #21 | |
mTekMods
2142
Rep 2,901
Makaveli7116.50 |
