09-11-2018, 01:34 PM | #1 |
Rep 407
Drives: E92 M3, E46 M3, NA Miata
Portable Tire Pumps
Looking for options for a quality, portable tire pump for track use at tracks where an air station isn't close by (or there at all).
I bought a cheap-ass one at Napa and the thing never worked. Short of lugging a huge air tank and really long extension cord to the track. What is everyone using for this? |
09-11-2018, 02:29 PM | #3 |
Rep 1,881
dont we have a factory air pump in the trunk? i have used it to fill a tire from flat to 40psi...
09-11-2018, 08:38 PM | #5 |
Rep 12,711
i use a relatively expensive pump, but i also use it for offroading (filling 37" tires up from about 10psi) because i don't want to wait forever. pretty decent and fast.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Chris_PDX337.00 |
09-11-2018, 09:53 PM | #6 |
Rep 531
I see a few guys at autocross use the Ryobi cordless inflator:
https://www.homedepot.com/p/Ryobi-18...P737/206159256 I personally only inflate between run groups and mostly just deflate in-between runs as the tires heat up, so I'm using a cheap-ish generic cigarette lighter inflator commonly found in any department store.
Boston BMW CCA Autocross ///408 E90 M3 |
09-11-2018, 10:22 PM | #7 | |
Rep 1,490
Viair 00088 88P Portable Air Compressor https://www.amazon.com/dp/B005ASY23I..._KyiMBb745ZCEK
2011.5 E90 M3 DCT ZCP Slicktop
09-11-2018, 10:42 PM | #8 |
Rep 554
I use this...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 super convenient at autoX and the track to inflate all tires to the same "target". also, $30 prime. I have several of the ARB and Viair for the off-road trucks, but its way more than we need for a BMW. |
Chris_PDX337.00 |
09-12-2018, 09:09 AM | #9 |
Rep 527
Drives: 2011 E82 135i, 2015 F15 X5 35D
I got a portable 10 gallon air tank (longacre sells a 5 gallon tank) that I prefer over the air pumps. Just fill it up before leaving for the event and its plenty of air for the weekend.
Chris_PDX337.00 |
09-12-2018, 11:27 AM | #10 | |
Rep 1,424
Chris_PDX337.00 |
09-12-2018, 11:45 AM | #11 |
Rep 10,553
I just got a Milwaukee 12V inflator that I like, but I have many Milwaukee 12V and 18V tools. If you gave a battery impact, see if the same company makes an inflator. Ryobi does, Ridgid does.
09-13-2018, 11:27 AM | #12 | |
Rep 407
Thanks all for the recs. I may look into the one that Visceral posted. Cheap enough I don't mind breaking it/losing it. |
09-14-2018, 07:53 AM | #13 | ||
Rep 1,424
09-14-2018, 09:49 AM | #14 |
Stop the hate, get a V8
3848
Rep 8,625
I got a cheap one from Harbor Freight. It works. I wouldn't really rely on it for repeated daily use, but for periodic top-offs or whatever, it's totally fine.
Past: 2011.5 M3 sedan ZCP |
09-14-2018, 11:18 AM | #15 |
Rep 407
3.8 is about as far as you want to go with street tires lol. It's already a handful on the freeway with that much up front.
09-14-2018, 11:34 AM | #16 | |
3848
Rep 8,625
THE NOISE < 80DB
Visceral363.00 |
09-19-2018, 04:15 PM | #17 |
Rep 71
I used to lug around one of the Craftsman battery-powered compressors, which worked great until the locking chuck lost its ability to hold on to the valve stem. I've got a big compressor and tank in the garage, so I grabbed one of the little yellow Harbor Freight air tanks and I think it's worth the slight increase in volume. Only thing is you can't be quite as generous letting other folks use it during the day, the 5 Gal tank can do about 30-35PSI worth of total pressure increase in tires the size of the M3's before it hits equilibrium.
