08-20-2018, 01:46 PM | #1 |
Rep 363
Time for rotor replacement?
Using a rotor caliper tool I measured the front rotors. There is a spot that reads 28.45mm. The minimum spec is 28.40. Is it safe to get another track day out of these? Also, my pads (PFC 08) are at 7mm. Do you run them down to 1-2mm?
08-20-2018, 02:52 PM | #2 |
1918
Rep 1,887
The rotors are fine for another track day if you're not using a really abrasive pad compound.
For the PFC 08 at 7 mm, you should keep a very close eye on them. I would buy a new set and keep these as a backup. They were 19 mm in the front when new so you've worn 12 mm away. You could probably get away with a day or two if you're on a track that isn't very heavy on braking from high speeds. Also with this level of pad wear, you're more likely to overheat the rest of the braking system. |
08-21-2018, 09:19 AM | #5 |
Stop the hate, get a V8
3850
Rep 8,625
You can run a bit past the "discard" thickness of the rotors, IME. It's not like being fractions of a millimeter below it will completely prevent the car from stopping. You will notice reduced thermal capacity, obviously. As others said, check for cracks big enough to catch a fingernail on or ones that go to the edge.
As far as brake pads, I would not run them down to 1-2mm. At that point you are putting tons of heat into the caliper and fluid. Experience has taught me that anything below 1/2 thickness is when you are starting to take a gamble. I know money doesn't grow on trees, but pads are relatively cheap compared to the time it takes to rebuild a caliper. Ask me how I know...
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 08-21-2018 at 09:30 AM.. |
08-21-2018, 10:19 AM | #6 |
Rep 396
Every pad I've pulled out recently was ran so far down it was missing pad material from the backing plate. I get my money's worth. One PFC 08 even had a hole through the backing plate.
08-21-2018, 10:29 AM | #7 |
Rep 363
I appreciate the feedback. I am running two more events this year. Looks like I will be able to run Thunderhill and Sonoma then replace the rotors and pads. There are hairline cracks running through the PFC 08's though. I do get huge brake fade even with brand new SRF fluid after 10-15 minutes into the session at Laguna. I'm looking at some sort of ducting to help. Are the PFC DD rotors a huge upgrade at almost twice the price of OEM?
08-21-2018, 11:01 AM | #8 | |
3850
Rep 8,625
Past: 2011.5 M3 sedan ZCP |
MPower790.00 |
08-21-2018, 08:03 PM | #10 |
Retired Curmudgeon
2985
Rep 4,047
0.05mm/25.4mm/inch = ~0.002 inches (slightly less than 2 thousandths)
I wear about 1 thousandth per event with PFC08's on stock brakes. Depends on the track, of course, with Laguna being more than 1 thousandth, other tracks less. Your rotor wear may vary.
08-21-2018, 09:51 PM | #11 |
3850
Rep 8,625
Call PFC technical support. They're quite helpful.
08-22-2018, 12:26 AM | #12 | |
Rep 12,726
https://www.m3post.com/forums/showthread.php?t=1323357
08-22-2018, 08:10 AM | #13 | |
3850
Rep 8,625
Yeah, I'd jump on that too. Outstanding kit and they rarely go up for sale.
08-22-2018, 11:31 AM | #14 |
Rep 363
Any negatives with this kit? Longevity, daily drive able?
https://www.m3post.com/forums/showthread.php?t=1505941 |
08-22-2018, 04:26 PM | #15 |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
For pads, the thinner they are, the FASTER they wear. So don't assume you've gone through X amount of events and only wore away Y mm, so that your Z mm pad will last you so many days.
I start buying spares when they're past 1/2 way mark just in case.
Sitting on a beat-up office chair in front of a 5 year old computer in a basement floor, sipping on stale coffee watching a bunch of meaningless numbers scrolling aimlessly on a dimly lit 19” monitor.
MPower790.00 |
08-22-2018, 05:31 PM | #16 | |
Rep 12,726
-I'm always a bit cautious of kits I don't see often. How hard is it going to be to find a vendor that sells replacement parts? -how far off is a caliper rebuild on that kit? History is a mystery. -rotors are almost shot. The slots are almost rubbed through and there are some visible (but normal) cracks. Rotors and hardware are probably north of $1k for that kit. Now, the PFC kit, i'd believe them if they told me it was brand new... it looks it. No mysteries.
MPower790.00 |
08-22-2018, 06:13 PM | #17 | |
3850
Rep 8,625
Yep, I've said that in this forum before. The density of the pad actually changes as it wears. Anything past 1/2 thickness and you are going to notice greatly accelerated wear.
08-22-2018, 06:14 PM | #18 | |
3850
Rep 8,625
Agree that it's clearly a heavily-used kit. The rotors are basically done, and I'd bet the calipers need a rebuild. I would check prices for the discs and caliper seals/pistons from Brembo. That kit, when new, is $6-8k! Still, that's a legit race setup and if you're fine with spending the coin to bring it back up to original condition, go for it.
08-26-2018, 04:53 PM | #19 | |
Rep 12,726
https://www.m3post.com/forums/showth...8#post23643568
