      02-18-2019, 07:36 PM   #1
jurrego
Drives: 2011 E90 M3 DCT
DCT paddle not working after paddle swap
I changed my paddles and now my upshift paddle does not work. The downshift paddle works fine. The knob works fine.
I re-did the install and it started working intermittently but has stopped again. So I opened it up again and cleaned the gold contacts. It is still not working though.
Any ideas?
      02-18-2019, 07:46 PM   #2
Ab28
Drives: E90 M3/E39 M5/128i
The contact patch needs to be raised ever so slightly in order to touch. You may have put pressure on it when removing and replacing it during the swap.
It only requires a miniscule amount of pressure to flatten it. Remove it again and have it flair up just a little. It will fix the problem.
      02-18-2019, 08:08 PM   #3
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
Also make sure the brown wires are not pinched
      02-19-2019, 06:11 PM   #4
jurrego
This worked. Thank you!
Ab28592.50
      02-19-2019, 09:20 PM   #5
Ab28
Happy to help.
      02-21-2019, 06:03 PM   #6
GORDON.M3
GORDON.M3's Avatar
Drives: E92 M3 • F25 X3 M-Sport
not to mention that the paddles have some dielectric grease applied on the ends of them to make it click smooth with the small bearing ball. You should clean the contacts with some isopropyl alcohol and a qtip.
INSTAGRAM: GORDON.M3
North American Mr12Volt Carplay/Android Auto Distributor
