      11-22-2016, 03:08 PM   #1
Aleksandar
Drives: BMW E93 M3
Knocking noise from steering, is this normal?
I have a question and if someone can help me I would appreciate that very much
E93 M3 2012 31.000 km, without MDM and w/o EDC.
Since I bought this car it has steering knocking from steering rack, less noticeable when the car is cold and far more after for example after driving.
I replaced both tie rods, both sway bar stabilizers and still knocking. I bought new Lower joint + upper joint but didn't replaced it cause the axle must go down and cause the sound comes from steering rack. In driving is everything fine but when I hit a deep hole I can feel it on stering wheel, when driving slow for example over train I hear a pretty loud clicking from steering wheel/rack.
M3 owners, if you shake the steering wheel back and forth without the engine running and after a drive, do u hear a strong klicking noise from the engine?
If you shake the wheel back and forth when the engine is running, do u feel (and hear too) a little like empty space when the wheel is on 12'?
I am sorry for my bad english too
This is the sound after driving, the camera was on air filter.
      11-24-2016, 06:28 AM   #2
Aleksandar
Drives: BMW E93 M3
No one?
      11-24-2016, 10:34 AM   #3
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Originally Posted by Aleksandar View Post
No one?
Check my thread a year ago, I had the same issue and was told it was normal...i replaced the rack and all suspension components associated with it. Still there.
So one day I went into the dealership and saw a 2013 model. Went inside and shook the steering. Same noise.
The thread says to replace the steering assembly, which I havent done yet.
      11-24-2016, 11:56 AM   #4
///mawana
///mawana's Avatar
Zimbabwe
80
Drives: e90 M3
Nothing normal about that sound, my '08 doesn't have it. I would guess, you need a new column or at least get the one you reconditioned.
2015 K46 S1KRR
2008 E90 M3
      11-24-2016, 11:20 PM   #5
Helmsman
Helmsman's Avatar
Sweden
4465
Drives: 2011 AW E90 M3 ZCP
Nope, mine doesnt sound like that.
      11-29-2016, 05:04 AM   #6
Aleksandar
Drives: BMW E93 M3
Do u mean column between steering wheel and steering rack? Or steering rack?
      12-02-2016, 07:47 AM   #7
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
the column between steering wheel and rack
I don't think this is a rack issue
      12-06-2016, 08:13 PM   #8
atruelunatic
Drives: n/a
Were you able to solve your problem? I just started noticing this on my car, 99k miles.
2011 e92 JzB 6MT
Akrapovic Evolution, ESS Tune, KW V3
      12-13-2016, 04:03 PM   #9
Aleksandar
Drives: BMW E93 M3
Not yet Identical sound..
I was till now in 2 bmw official service/repair shop and they said the rack is perfectly fine and I am imagining..lol
Before this I was at my mechanics and they said this is 1000% the rack. Cause when it gets hot the material stretches and there is a little play..I had the same issue 9-10 years ago on my E46 coupe, when was cold (first 20 mins after engine starting) and untill the joint gets very hot and stretches. After new joint was installed everything was fine. Howewer there was no clunk, only some free play and knocking from steering wheel instead steering rack.
I am thinking about installing new rack, 1400 €. But if this is not the rack fault, dont know then what to do..
      02-07-2019, 09:19 PM   #10
Cbozz
Cbozz's Avatar
Drives: M3
did you solve this issue? I have the same sound when car is off... I didn't notice any noises when driving..
Evolve, Eisenmann, Strasse, StopTech, Active Autowerke
      02-10-2019, 04:21 PM   #11
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
That video above is def the steering shaft.
G-Power Supercharged
      02-11-2019, 02:59 PM   #12
Cbozz
Cbozz's Avatar
Drives: M3
I think it's my knuckle due to the temperatures being in negative's.... like someone said here the metal shrinks and there is some knocking when car is off... when running or when warm - no noise at all...
guys on here mentioned this is something I shouldn't worry about... should I just swap out this knuckle for peace of mind?
It does sound like it's coming form the knuckle when I have someone move the steering wheel for me...
      04-14-2019, 05:52 PM   #13
S14turbo
Drives: 320is Stock 320is turbo E90 M3
Same Problem here, is there an solution?
Done already:
Strut Bearings changed.
New steering rack screws.
All Screws in Front axle losen and pulled with right torque.
