      08-05-2019, 11:45 AM   #1
zipper228
zipper228's Avatar
202
Drives: 2011 E93 M3
Off-center steering wheel/looser steering to one side
Hoping for a bit of diagnostic help here so I can direct my indy appropriately.
Searched a lot but haven't found a clear answer to my specific issue.
Steering wheel is off center by maybe a 1/2" or so to the left when the car is tracking straight, meaning I'm constantly driving with the wheel slightly turned left. I had an alignment done recently which I hoped would solve this but didn't. I've also noticed that the steering feels slightly "looser" to the left than it does turning to the right. Not sure if this is just perceived in my head though due to the fact that its already off center (hence the feeling that going just slightly past center to the right has a tighter feel than the other direction).
Anyone else dealt with and solved this or have an idea as what specifically I should be asking them to fix/adjust? Huge thanks in advance!
      08-12-2019, 09:30 AM   #2
CurbBender'90
S
CurbBender'90's Avatar
Drives: 2010 S65
I had a slight similar issue and would love to know what causes this and how to correct it! This is something that would drive me nuts because "the car wasn't built that way so it should be straight" logic..
DCK
      09-10-2019, 11:33 PM   #3
jballer123
Drives: 2011m3 zcp
I had this and replaced my front tension arm bushings with power flex black bushings and it removed 90 % that feeling and vibration!!!
      09-11-2019, 07:20 PM   #4
M43S7RO
Drives: Jerez Black E92 M3
Sounds like you need a different indy and alignment shop. You shouldnt have to figure things out for them on forums.
