      10-30-2017, 08:25 AM   #1
Su37su
Drives: Lancer Evolution X
P2430 and P2432 Increased emissions
I will like to ask for your help.
I have check engine light with the following codes:
p2430:Sec Air Injection System Airflow/Press Sensor Circuit Bank 1
p2432:Secondary Air Injection System Air Flow/Pressure Circuit Low Bank 1
Increased emissions
I've done my research and it appears that I might have a crack on the suction hose(11727838504) or bad sensor. I stopped at a dealer and was quoted $200 for the part.
Is there anything else I should look for before purchasing the part?
The car drives fine but I don't know if it's safe to drive the car with the check engine light on.
Any help will be appreciated.
      11-03-2017, 09:04 AM   #2
Candide13
Candide13's Avatar
180
Drives: '11 E90 M3 ZCP 6MT AW/FR
Increased emissions
I had this part fail on my car twice, first time it was replaced by dealer under warranty, second time I did it myself. There is no risk in driving whatever, the part is only active in the first 30 seconds or so of the cold start cycle. It blows extra air into the exhaust to heat up the cat as quickly as possible.
If you do the work yourself I recommend buying the part from fcpeuro, who give a lifetime warranty so if it fails again they will give you a new one free of charge
      11-03-2017, 11:50 PM   #3
Su37su
That's good to hear because I daily drive this car. I purchase the part off eBay for $55 shipped.
      08-22-2019, 12:41 PM   #4
Ralphy_Banks
Drives: BMW M3
Hey guys I have a few questions so these codes keep popping up (2739 - 27C5) on I change the Air Suction Pump Hose already & my engine malfunction light still comes on, any idea what it can be
I look up the codes & it says
description for 2739 says "AIR MASS SENSOR SECONDARY AIR ELECTRICAL DIAGNOSIS"
Secondary Air Injection System Air Flow/Pressure Sensor Circuit High (Bank 1)
description for 27C5 says "AIR MASS SENSOR SECONDARY AIR SIGNAL"
Secondary Air Injection System Air Flow/Pressure Sensor Circuit (Bank 1)
Search this Thread:
Advanced Search
Copyright ©2000 - 2020, vBulletin Solutions Inc.
