      08-26-2022, 05:19 PM   #1
spooni
spooni's Avatar
481
Drives: '11 E92 comp
Another alignment thread
Suspension: Nitron R1
Here's my current specs. I'd like to dial the car in a bit, any suggestions? I had some pushing last track day.
I was thinking another -0.5 of camber up front, rear I believe is maxed out. Where else can I improve?
IG: @M3spooni
slcook541863.00
      08-26-2022, 05:46 PM   #2
slcook54
slcook54's Avatar
1863
Been chatting with Phil at Bimmerworld. This is what I'm going with next time out.
Instagram: slcook54
spooni480.50
      08-26-2022, 06:30 PM   #3
omgzirra_exe
omgzirra_exe's Avatar
Drives: 4.4L M3, IS300
pretty close to my alignment, based on what cook showed.
-3.2F driver -3.3F Passenger
7.5 Caster
0 toe front
-2.5R Driver and passenger
1/8th toe in rear.
i am also corner balanced.
-3.5 would be ideal.. but once i get some more testing in and checking tire temps.. i'll know to add more if needed.
-3.2/.3 w/ 0 toe front is pretty good for a street/track compromise too.
Build: ZillaSpec M3 N1 Build
#fakeGTS
slcook541863.00
spooni480.50
      08-27-2022, 07:15 AM   #4
rhyary
rhyary's Avatar
Drives: 2013 M3
I have a good tire wear and success with:
Front -3.5 camber, Toe out .05
Rear -2.5 camber, Toe in .05
Pic front tire wear after 3 hard days at WGI:
spooni480.50
      08-31-2022, 12:58 PM   #5
tsk94
tsk94's Avatar
Going to -3.5* could help. I'd do 0 toe up front as well. What's the deal with that rear toe?
Pushing at what phase of the turn? Alignment could help, but it might be more related to damper settings, sway bars, etc.
