BPM
      01-22-2021, 10:34 AM   #1
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
Remote Resi - nitrogen rig list/guide
Hey guys and gals, I hadn't seen really anyone put together a list for a nitrogen rig kit. There's a couple of really nice ones out there but they are over 6-700 bucks . Here is a list of what I have purchased, and should be great for a hobbyist, i don't see me needing more than a 5lb on a track weekend if I do...I'm in trouble. This tank is only 18x5". I also prefer aluminum as they are much lighter than steel tanks.
You should be able to get this tank filled by a local welding supply for about $20-30. Some suppliers are swap out only, so make sure they do filling at the place you go to. Don't want them snagging your fancy new aluminum tank.
5LB 20CF tank:
https://www.ebay.com/itm/5lb-20cf-Al...eede%7Ciid%3A1
Nitrogen regulator:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
60" hose:
No loss shock fill tool (couple ones you can use here):
https://www.ebay.com/itm/15399584432...4aAtQSEALw_wcB
https://www.bimmerworld.com/Suspensi...caAnQdEALw_wcB
2010 E92 M3 DCT
okusa845.50
tsk941522.00
      01-22-2021, 10:51 AM   #2
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
This one looks neato too.
https://www.amazon.com/Longacre-5047...ustomerReviews
2010 E92 M3 DCT
okusa845.50
      01-25-2021, 07:24 PM   #3
dogbone
dogbone's Avatar
5353
Drives: '09 E90 M3 - IB
2009 BMW E92 M3  [0.00]
2009 BMW E90 M3  [0.00]
Whatever you get, just make sure it has a convenient button for bleeding air out of the line. Once I hook everything up, I like to make sure I bleed all the ambient/humid/crappy air out of the line with nitrogen before I open up the canister.
Move Over1256.50
      01-25-2021, 08:32 PM   #4
Estoril Blue
Drives: 2006 M3
Anyone know of a Youtube DIY?
      01-26-2021, 04:47 AM   #5
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
What are you looking for specifically?
2010 E92 M3 DCT
      01-26-2021, 02:11 PM   #6
Estoril Blue
Drives: 2006 M3
I've never seen the process or the plumbing of those components and would like to understand it.
      01-26-2021, 02:40 PM   #7
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11480
I got one of these:
https://powertank.com/collections/po...ice-descending
With a carrying suitcase and everything.
      01-26-2021, 04:23 PM   #8
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
Sure, this is basically for adjusting pressure for remote canister shocks. This isn't something you plumb in, but rather carry to the track with you to adjust pressures. The regulator screws into the tank
2010 E92 M3 DCT
      01-26-2021, 04:26 PM   #9
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
I got one of these:
I dig it, but I couldn't justify spending 7-900 on a kit.
2010 E92 M3 DCT
SYT_Shadow11479.50
      01-26-2021, 04:40 PM   #10
SYT_Shadow
SYT_Shadow's Avatar
11480
Tell me about it. And i never use it, the mcs shocks maintain their pressure quite well
      01-26-2021, 05:00 PM   #11
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
Good to know...I had moton doubles and they were ok. I found maybe 8-10 psi every month
2010 E92 M3 DCT
      01-26-2021, 05:38 PM   #12
SYT_Shadow
SYT_Shadow's Avatar
11480
i think i lose that per season
      01-26-2021, 05:55 PM   #13
JScheier
Drives: GTS3 BMW E36 in NASA
Make sure the tank setup you select has a cage around the top of it, so if it dumps over you don't snap the neck and create a missile
SYT_Shadow11479.50
admranger2984.50
      01-26-2021, 07:36 PM   #14
Move Over
Move Over's Avatar
1257
Drives: M3 6MT
2010 E92 M3 DCT
      02-02-2021, 04:56 AM   #15
roastbeef
roastbeef's Avatar
i have a powertank that i used for offroading, but we use c02 to fill the tires. its about ten years old and the last few times i've had it filled they try to tell me the tank is expired and it might leak (it doesn't). i could probably use the same tank and regulator, and just buy the longacre inflator.
if my tank has a regulator, does it need a specific regulator for nitrogen?
also, how often are you guys checking and changing the pressure of your shocks?
