      07-02-2015, 10:09 PM   #1
Strick
Drives: 2022 X3MC, 2019 M2C
2009 Enhanced premium sound - No bass drivers side
Today while driving home from work I noticed that the drivers side bank of my stereo no longer has any bass; I confirmed this via EQ tweaking. Passenger side seems to be unaffected. Doubtful is just a sub issue as its both front and back being affected.
My guess is that it's water damage to the amp, it's rained A LOT the past few days. Going to pull things apart tomorrow to check it out.
Assuming the amp is the culprit what viable options do I have? I could pick up a used EPS amp and stick with OEM stuff. However I'd be willing to go the aftermarket route.
Any help would be appreciated!
Thanks!
      07-03-2015, 11:45 AM   #2
Strick
Removed the amp today to do a visual inspection and everything seems to look alright. No water damage, no bad capacitors etc.
I wish I knew how to diagnose a bad amp myself. I'd feel really bad dropping $600+ to replace this thing if the culprit was a bad solder connection or something stupid of that nature.
Are there any shops/people that are able to diagnose and repair this?
      07-03-2015, 11:56 AM   #3
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
I think I'm having the same problem. Though I turned the radio up one day put my hand on each of the EPS speakers and found no vibration on the drivers rear speaker. I ordered a new one from ECS (they're on sale) and plan to install today or tomorrow hopefully that solves it
      07-03-2015, 12:22 PM   #4
Strick
Not sure we're having the same issue, your problem seems isolated to one speaker. My system just lacks bass on all left side channels.
      07-03-2015, 01:19 PM   #5
dpilat8588
2010 BMW M3  [0.00]
Thanks!
similar thing happened to me the other day...driver side subwoofer randomly went out...ordered a new one from ECS so I'm hoping a new one solves the problem
      07-03-2015, 01:35 PM   #6
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
That's what I'm saying I wasn't getting bass on that side either a lil sound but no bass vibration. Did you check all you speakers to make sure they're working?
This is what I found as you can see no bass was coming out of that
      07-03-2015, 01:47 PM   #7
Strick
I'm not getting anything at all from the drivers side. It seems some of the mids are gone too.
      07-03-2015, 02:02 PM   #8
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Here's the link I used to replace the speakers
http://www.m3post.com/forums/showthread.php?t=672734
Maybe take a look and see if the speakers themselves are blown might save you money going after the amp if that's not the prob
      07-04-2015, 12:11 AM   #9
Strick
Took the woofer out today and discovered one of the leads going into the magnet was broken. Pain in the ass soldering it, but luckily all is well.
I must say this much, I'm shocked it was just the sub. Sounded like much more was missing, surprised at how much sound it puts out... Now I'm really thinking of tossing in a set of sws 8s under the seats and a nice 10 in the trunk. I haven't had a sub since highschool days...
      07-11-2015, 10:18 PM   #10
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
I took my sub out and found the same problem. Can you tell me how you were able to solder it? It doesn't seem like the frame comes out...
      07-12-2015, 01:26 PM   #11
Strick
I was sort of lucky and had the lead break off near the terminal, I bent the tab down a bit to make more room. Was close.
      07-12-2015, 09:22 PM   #12
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
Oh I see...mine is severed further inward...guess there's no fix
Thanks
      07-14-2015, 08:13 PM   #13
dpilat8588
2010 BMW M3  [0.00]
Thanks!
My driver side sub went out about 2 weeks ago so I ordered a new sub (assuming it wasn't my amp that blew). When I pulled the old one out, I found that the one wires had snapped. See the damage in the below pic. Thank god it wasn't my amp.
      07-15-2015, 11:45 AM   #14
Strick
Mine broke in the same location, was fixable as stated.
      07-15-2015, 12:01 PM   #15
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
I lost bass on both subwoofers.
It comes and goes randomly while driving. You think it could be the subwoofer leads on both sides went out? I went through the hassle of replacing the amp and it was not that.
You have to remove the seats to get to the sub?
Auto Detailing Enthusiast!
      07-15-2015, 12:07 PM   #16
Flying Ace
Flying Ace's Avatar
4985
Drives: G05 45e, 997.1 & 991.1 GT3s
I also loss bass. I'm all about that bass, no treble.
      07-15-2015, 12:29 PM   #17
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
I think so. The vibration probably puts the leads in and out of contact. Yea seat has to come out. Four torx t50 bolts and a regular torx bit set to get the rest out
      08-15-2015, 09:08 PM   #18
waldron80
waldron80's Avatar
Drives: 08 e90 M3 6MT
Same exact problem here too.
      08-20-2019, 12:49 PM   #19
su_root
I have a similar issue that popped up over the weekend.
Tweaking with the EQ settings and moving sound around the car (left, right, rear, etc) to isolate a particular speaker I notice there is no bass when all audio is on the left side(driver side).
i also noticed my front center speaker sounds like its blown(statick-y when playing back some sounds). not sure if speaker or amp related.
before i go through ordering speakers and/or replacing the amp(last resort). anything else i can check for.
could the radio have been played so loud that a lead on the left sub broke AND the center speaker was blown? only reason i bring that up is the car was at a shop over the weekend
      08-20-2019, 02:17 PM   #20
EJT86
EJT86's Avatar
Drives: 2018 M2
  [0.00]
2018 BMW M2  [0.00]
The lead wire is the weak spot and is what is usually broken. The way it’s designed you’d be extremely lucky to reach enough of it to solder it. I’m not 100% sure if the center speaker is for music or if it’s just for the voiceover (nav instructions etc). Pull the sub and you will clearly see if the wire is severed
      08-31-2019, 09:20 AM   #21
Ikejones
Drives: 2007 335i
My driver side went out as well. Replaced both driver and passenger with the subs from my old e92 with logic 7. Also replaced the center speaker on the dash as well. It sounds sooooo much better now.
      09-05-2019, 05:38 AM   #22
su_root
where did you source the center/dash speaker ?
