04-26-2020, 10:24 AM | #1 |
Rep 3,834
MPorium M3 Aluminum Undertray - A must for M3s!
I was about to replace the felt undertray of my track E90 M3. OEM options were over $400 and wouldn't last more than a year. I discovered MPorium M3 Aluminum Undertray and couldn't be happier with the build quality and fitment.
deansbimmer make these, cool guy. Just be patient as they could take a couple weeks to make. OEM vs Mporium Aluminum Undertray. OEM tray was cracked and one of the weather strips to the oil cooler was gone, causing a rise in oil temp. Screws and Drill Bits included Installed photo. I could've added more screws on the side, but these were enough and sturdy. I highly recommend this mod for the same as OEM replacement. This does a better job at protecting the oil cooler, less likely to rub against driveway curbs, and will last the life of the vehicle.
Daily: G12 750 MSPORT Weekend Car: E90 M3
04-26-2020, 12:11 PM | #2 |
vvvvvvvvvvvvvv
332
Rep 2,305
On the OEM setup, there is a felt box on each end that sits lower than the main tray. I don't see that on the MPorium version. What is the purpose of that felt box? aerodynamics?
04-26-2020, 01:39 PM | #4 | |
Rep 3,834
I can think of a few reasons why the OEM is like that: (1) The OEM central piece is held by these stupid steel cable with nuts, it's super annoying. The side pieces hang down to match the center piece for easy access to the hanging bolts and nuts. Mporium don't require these hanging cables, which is a huge relief. (2) The OEM hangs down to be a "feeler" component, warning you not to drive further if you're close to a tall obstacle. However, the OEM cracks so easily so that is useless. (3) OEM piece is designed to be assembled quicker, no drilling or eyeballing to fit.
04-26-2020, 02:33 PM | #6 | |
Rep 3,834
The difference is OEM gets destroyed so easily, when the felt pieces crack or punctured the oil cooling function deteriorates. These will not crack or get punctured. I'm not doubting that OEM felt's hump creates more negative pressure which pulls even more air out, but when you hit a single debris on the highway the felt cracks or punctures which throw that nice idea out the window. So far, no one reported oil cooling issues with these. In fact, I'm sure my oil temp will lower as my OEM felt was cracked and one the weather strips were missing causing air leakage.
04-26-2020, 04:09 PM | #7 |
Rep 3,834
Side bonus is we can remove the undertray without removing the wheels. Just remove all bottom screws and out it goes thanks to the end L brackets. So I just leave L brackets attached to the fender lining when removing.
04-26-2020, 05:04 PM | #11 |
mTekMods
2124
Rep 2,888
04-26-2020, 05:19 PM | #12 | |
Rep 258
I don't know what a gt4 splitter adds to the equation. |
JNoSol1381.00 |
04-26-2020, 06:16 PM | #14 | |
Rep 3,834
Also, maybe I'm crazy but the I can hear more engine sound. Maybe the felt insulates the sound and aluminum amplified it. Hope others with it can chime in to make sure I'm not imagining it.
04-26-2020, 06:25 PM | #15 |
Rep 258
It wouldn't surprise me--I think the felt is part of noise abatement for European regs. Or maybe I just dreamed that.
05-11-2020, 11:58 AM | #16 |
Rep 305
05-11-2020, 12:24 PM | #17 | |
Rep 355
https://mporiumbmw.com/ |
05-11-2020, 12:40 PM | #18 | |
Rep 1,881
05-11-2020, 07:19 PM | #19 |
I got lei'd
844
Rep 7,593
05-15-2020, 11:09 PM | #20 | |
Rep 3,834
deansbimmer feel free to chime in.
05-25-2020, 07:55 AM | #22 |
Scrappy Coco
62
Rep 447
Drives: 2012 M3 AW DCT ZCP ESS 625
Which is the steering line in this pic that needs bending? This is one of those installs that you hardly see, but feel good about doing 👍🏻
Alpha///M
ESS VT2 625- GTS DCT Tune- Full Challenge Exhaust- Mode Carbon- Other Stuff |
Tags |
aluminum tray, e90 m3 undertray, e92 undertray, mporium under tray undertray |
