09-25-2018, 12:29 PM | #1 |
Rep 53
Drives: 2011 BMW M3
So I went to my local NAPA and they have Liqui Moly 10W-60 for the cheapest I've ever seen for a 5L, $43.09!!!
That's not my issue. My issue is the Diff and Manual Trans Fluid. Now for the diff Fluid, my Indy tech says to go with the OE BMW brand, due to the Liqui Moly brand causing friction and noise. I'm fine with that. FCP Euro sells the BMW brand in a kit. Are there any OE alternatives that anyone uses without any issues, for future fillups? Also, the MTF Fluid is a bit confusing. Can I use the Liqui Moly branded GL-5 75W-90 or 75W-80 without consequence? I know the 75w80 is for DCT, and the 75w90 is MTF, but is there really a big difference beside just thickness? Or should I stick with Pentosin FFL-4, which also by the way doesn't give reference as to what the weight is? It does say on FCP Euro that it replaces the MTF-LT-2. Also, does anyone know what the OE actual brands of differential and manual trans fluids are? Lol a bit confusing
BavarianNeM3sis
09-25-2018, 03:02 PM | #2 |
1918
Rep 1,884
I used the 75W140 LM diff fluid and it works well. Didn't notice any noise since I was enjoying the lack of harshness from the OE diff fluid.
09-25-2018, 04:09 PM | #3 |
Stop the hate, get a V8
3850
Rep 8,625
OEM transmission and diff fluids are Castrol.
MTF-LT-2 is actually a 75w80. If you look at Red Line's recommendation of D4 ATF, it's a 70w80. Their tech support guys have said that some people mix the D4 ATF and MTL90 (75w90) to get something close to a 75w80. Rear diff is 75w140 with LS additive. It's Castrol Syntrans LS (formerly known as SAF-XJ) but with extra FM added to quiet things down. You can use pretty much any 75w140 as long as it has the LS additive -- or just add your own.
Past: 2011.5 M3 sedan ZCP Last edited by dparm; 09-25-2018 at 04:19 PM.. |
09-25-2018, 04:28 PM | #4 |
Rep 5,506
I've found that diff does not make any noise when cold anymore even without FM additive. All you need to do is go track the car a few times and it no longer makes noise. I just use straight SAF-XJ. Less slip = more grip.
Auto Detailing Enthusiast!
09-25-2018, 07:35 PM | #5 | |
Rep 53
Drives: 2011 BMW M3
BavarianNeM3sis
09-25-2018, 07:38 PM | #6 | ||
Rep 53
Drives: 2011 BMW M3
BavarianNeM3sis
09-25-2018, 07:40 PM | #7 | |||
Rep 53
Drives: 2011 BMW M3
BavarianNeM3sis
09-26-2018, 12:43 PM | #8 |
3850
Rep 8,625
Limited slip additive changes how the differential ramps from locked to unlocked. You need it, but the dosage is somewhat to personal preference. I tend to revert to the BMW standard when in doubt, as this is something they would of course test for.
The situation you want to avoid is abrupt transitions from locked to open, or getting into a gray area where it's constantly locking and unlocking. Both of these would unsettle the car and make the handling less predictable.
Past: 2011.5 M3 sedan ZCP |
