05-24-2020, 10:05 AM | #1 |
M3NTAL
132
Rep 608
Anybody Have 275/295 PS4S on Their ZCP?
I currently have a 275/295 PSS setup on my E92 ZCP (stock suspension), and it's almost time to order a new set. I've been reading that PS4S tires have a slightly wider shoulder than PSS, even though Tire Rack lists both with the same 11.9" section width and the PS4S having an 11" tread width versus 11.5" for the PSS. The PSS had a very slight rubbing on the rear fenders at near-full compression when they were new, so I don't think any wider will fit. Curious whether anybody has PS4S tires in these sizes on their ZCP (E90 or E92) so I know whether they'll fit. Thanks!
05-24-2020, 11:06 AM | #2 |
bOrN To DiE
413
Rep 1,738
I know some runs 275/30 front 295/30 rear but I really dont like the look and wouldnt run 295 on 10'' wheels. What is the reason you dont wanna run 255/35 F 275/35 R? Cheaper and safer plus I see that you live in NY and some roads are horrible there. I guess 255/275 option is better,safer and cheaper at least you'll have some meat.. Answering your last question is they do fit based on reading some guys post here..
05-24-2020, 09:45 PM | #3 |
M3NTAL
132
Rep 608
I actually like the more flush/squared 275/295 look. From pictures the 255/275 setup still looks slightly stretched to me (even with PS4S tires), though I haven't seen many in person. Plus, to get the tire more flush with the fenders with the latter I'd need to run spacers. That said, I'd consider going to 255/275 if I can't confirm whether a 275/295 PS4S config will fit first.
05-24-2020, 10:07 PM | #4 |
Rep 765
I run 295/30 Ps4s on the rear zcp wheels and zcp suspension and they do not rub for me.
I run 255/35 up front so can't speak to the 275 fitment but my size rubs very slightly on full wheel lock. Not enough to cause any damage or make me care about it. Would be curious if the 275/30 Ps4s ends up rubbing. |
05-25-2020, 09:13 AM | #5 | |
M3NTAL
132
Rep 608
I'm pretty confident 275/30 PS4S would fit up front, I had no rubbing with that size in PSS. Just the rears were close. |
gh0stE92M3159.00 |
05-29-2020, 05:52 PM | #6 | ||
Rep 210
Not sure if that will work. I have a e92 zcp with stock suspension and stock zcp wheels, it's running the stock setup for tires but was thinking of going a little meatier. All I've seen is people running the 255/275 route. |
05-30-2020, 10:34 AM | #7 |
M3NTAL
132
Rep 608
I'm pretty confident neither of those sizes will fit well. There's numerous reports of 265/35 rubbing the liners and a few of 285/35 doing the same.
I actually got confirmation from mgmarsh39 in the "ZCP Love" thread that 295/30 PS4S will fit with no rubbing, which is what I was looking for. He has 255/35 up front, but 275/30 should fit fine in PS4S. |
mgmarsh39255.00 |
07-01-2020, 06:40 PM | #8 |
Self Proclaimed Roundel Junkie
627
Rep 1,593
Also here for some input. I'm on an E90, stock ZCP suspension and wheels.
I'm having major traction issues with my OEM size PS4S... Also looking to maximize sizes and it looks like 255/35 up front is best. As for the rear, looks like 275/35 or 295/30 are closest to OEM overall diameter... 285/35 and 285/30 are both over 2% different in size... So, where's my best option??? Also, I'm running a 15mm spacer up front and 12mm in the rear... Will these have to go? Thanks for the input...
2018 F15 X5d Carbon Black/Nutmeg Individual- Oil Burner Tow Rig
2013 E82 1M3 Carbon Black/Black- S65/DCT Track Toy 2013 F25 X3 35i Alpine White/Chestnut- German American Family Hauler Past: '11 E91 335is, '11 E90 M3, '10 X5M, '14 328d, '03 330i Dinan3 ZHP, '04 330i ZHP, '12 X3 35i |
07-05-2020, 10:03 AM | #9 | |
M3NTAL
132
Rep 608
As stated, I'm on 275/30 295/30 PSS now (without any spacers) with no issues. It's the closest to factory diameters and retains the same 20mm stagger while adding a good amount of width, at the expense of some tramlining due to the wide fronts and maybe a little less tight of a feel since they're on 9" and 10" wheels (0.5"-1" wider wheels would be ideal for these sizes). Since they're slightly shorter diameter than stock, it also yields a shorter effective gear ratio, so there's a slight acceleration benefit too |
07-05-2020, 05:58 PM | #10 | |
627
Rep 1,593
07-05-2020, 07:46 PM | #11 | |
Rep 355
07-05-2020, 08:28 PM | #12 |
Rep 12,725
i run 275/30 and 295/30's. they look good, but they are heavy and probably not the optimal size. these are only for the street though.
11-28-2020, 09:29 AM | #14 |
M3NTAL
132
Rep 608
Not yet, decided to wait until next year. Still have the 275/295 Pilot Super Sports that I installed in 2013 on it (I only drive the car about 2k miles per year). Still happy with the sizes to go for the same in PS4S though.
06-11-2021, 06:59 AM | #15 |
Rep 143
I'm about to pull the trigger on some PS4S in 275/30 19 & 295/30 19, can anyone confirm run/no rub on stock ZCP suspension and wheels?
2013 Fire Orange II E92 M3 ZCP
Bimmerworld (Quad) Resonated X-Pipe, AFe Stage 2 CF Intake, Carbon Project CF Plenum, Epic Motorsports Race Tune, Rogue Engineering Power Pulleys, Continental Extreme Contact Sport |
09-28-2021, 06:17 PM | #16 |
Rep 9
I have a 265/295 PS4S set up from when I bought the car a month ago with stock ZCP suspension/wheels - no rubbing whatsoever. Thinking of lowering on swift spec r springs next!
