11-29-2018, 10:26 AM | #1 |
Rep 185
Drives: 2012 E92 M3
275/35/19 vs 265/35/19 Rears Re71R
I’ve been doing some searching around this and it seems the Re71r’s run big. My car is lowered on Dinan springs so not that aggressive but I want to make sure the 275’s will fit. This is a weekend only/track car with a Level 3 AA supercharger so I’m looking for maximum traction. Thinking about a 275/30 as well. Any thoughts on this?
992 C4
11-29-2018, 01:09 PM | #2 | |
Rep 6,734
In general 275/35/19 is an easy fit on an e92. There's room for 295 or even 305's.
'23 X7
scrammer421.50 M3ANMACHINE929.50 |
11-29-2018, 02:44 PM | #3 | |
Rep 185
Drives: 2012 E92 M3
I have 275/35 PSS now.
992 C4
11-29-2018, 03:00 PM | #4 |
Rep 104
They fit fine on my 220s at that size. Only had slight rub up front at full turn in parking lots. The tire is just a bit more square, it has less roll-off, if you will, on the outer edges. After about 2k on them it went away.
Randy W.
'19 S550 Mustang GT PP1 DD/Auto-X |
11-29-2018, 04:31 PM | #5 | |
Rep 185
Drives: 2012 E92 M3
on his E90 and they looked huge. He said he bought the 275/30’s because of it. I think i will just order the 275/35’s and go with it.
992 C4
11-29-2018, 05:23 PM | #6 |
Rep 6,734
Look at it this way. It's common to run 12mm spacers on ZCP wheels with 275/35/19 Michelins (that's what I did in the past at least). Even if the RE71R runs wide, they sure aren't going to run 24mm wider than a Michelin. In other words, ZCP wheel without spacers has plenty of room on the outside.
'23 X7
11-30-2018, 08:34 AM | #7 |
Rep 104
Just so you know, they claim to be 200 tread wear, but they're not. More like 180 or less. SO, they will wear quickly. I got one auto-x season out of them including about 6,000 miles of daily driving. And that might be modest. With that said, they are hands down the best tire I've ever driven on. The braking traction you get is incredible. They're predictable and only squeal in turns just to let you know you've almost reached their limit. Oh and they're loud on the highway. Hope that helps.
Randy W.
Surquhar47.00 M3ANMACHINE929.50 |
11-30-2018, 02:20 PM | #8 | |
Rep 185
Drives: 2012 E92 M3
992 C4
thasuperdude104.00 |
12-05-2018, 10:58 PM | #10 |
Rep 2,360
I don't know if it helps since you are using I run 265/35/18 RE71R on front and 285/35/18 RS4 on rear without rubbing.
My stock sizes are P zero 245/35/19 front and PSS 265/40/19 rear.
Pass me if you can.
Surquhar47.00 |
12-22-2018, 01:14 AM | #11 |
Rep 87
Drives: 2009 M3 DCT coupe white/beige
Tire sizes
I was running 265/30/19 front and 275/35/19 rear Yokohama Advan AD08R
Rears were worn, this time I got 295/30/19 rears, they are slightly shorter and definitely wider. Accelerates better, the car was neutral now understeers because of the extra rear rubber, definitely more rear lateral grip. I have fully adjustable suspension, AST 3 ways etc. I am going to put my rear sway bar one setting stiffer or the front one setting softer to balance out the car. No rubbing at all in the rear, the front rubs slightly at full lock but never under driving. I thought about the RE71 R but they don’t have a 265/30 or 275/30/19 for the front. The e92 is heavy and needs wider tires than will fit up front.
Regards,
72dan |
Surquhar47.00 |
