INDustry distribution
      01-17-2017, 11:51 AM   #1
Mvez
Mvez's Avatar
73
Drives: 2013 M3 coupe
Solid subframe bushings with stock diff bushings
I know this subject has been beat to death, but as title states, anybody running solid subframe mounts with stock diff bushings? 6MT specifically. Seems like not many are doing this.
My car is heading in for a major overhaul, and while it will see track duty, it also will see street and highway driving. I know even the purple and black powerflex transmit a lot of whine. Wondering who has done just the subframe only, and how it is holding up on track?
I ran this exact setup on me E46 M3 for years on track with no issues, but the E92 does have a lot more power through the drivetrain. Me thinks the solid subframe would help stabilize the diff more, even with OE bushings. Didn't the GTS come with solid sub mounts and stock rubber diff mounts?
'18 GT3 - 6MT (Dec. build date)
'13 E92 M3 - street/track
'07 Cayman S - track car
'00 Miata - racecar
      01-18-2017, 11:58 AM   #2
tlrid3r
DISITRB
tlrid3r's Avatar
Drives: e92
I have been running that setup for years still ok but I do get wheel hope with track tires.
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, Volk TE37, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      01-18-2017, 09:41 PM   #3
Mvez
Mvez's Avatar
73
How would you get wheel hop on track? It's not like you are launching....at the track.
'00 Miata - racecar
      01-18-2017, 10:26 PM   #4
slicer
slicer's Avatar
Drives: '13 E92 M3
He said wheel hop with "track tires". Nothing about actual track use. I think the extra grip provided by r-comp tires can exacerbate the wheel hop issue. I would suggest some mid-level stiffness for your diff bushings if whine is a big concern. There is whine with solid or delrin bushings. I didn't think delrin was that bad but I didn't DD the car.
'13 E92 M3 - Alpine Wht - Ohlins TTX, Fall-Line / SPL Suspension Arms, Eibach Sways, MRF Solid SF Bush, AP Racing Brakes (Essex), Cobra Seats w/BK Mount, Akrapovic GT4, CSF Cooling, VPhreaks Battery, OE M3 GTS - Lip and Interior, M235ir Wing, Varis Diffuser, BBS E88
'17 F31 M-Sport - 513M Wheels, H&R Springs
'Instagram - @slicer_m
      01-18-2017, 11:42 PM   #5
becausephilchow
Drives: 08 E90 M3
I have Macht Schnell Aluminum Subframe Mounts along wiht Purple Powerflex Bushings being installed right now.
Spoke to a local who had this setup, with Turner Subframe Mounts/Purple Powerflex, and he said the whine wasn't too bad. Barely noticeable.
Figured since my car has 72000KM (45000 Miles) of full city driving (We don't really have highways here in Hong Kong), might as well change them out while it's all out and the labour is easy to do.
MFL76.50
      01-19-2017, 12:40 AM   #6
MFL
MFL's Avatar
77
2010 BMW M3  [4.50]
Go with Solid subframe + Powerflex Purple.
      01-19-2017, 01:24 AM   #7
tlrid3r
DISITRB
tlrid3r's Avatar
Drives: e92
Just when I'm getting into to track and full throttle I get a bit of wheel spin and goes into wheel hop. A few times when I drove home on track tires cause I was too lazy to replace at the track and standing at a light if I punch it I get wheel hop and I lift
      01-20-2017, 02:24 PM   #8
dj_dub
NoFüknJoke
dj_dub's Avatar
Philippines
877
Drives: 2010 BMW E90 M3 - SG/FR 6MT
Before I order my diff bushings...can someone please confirm that the "Street" bushings are the Purple ones and the "Race" bushings are the Black? Also, I need both the Front and Rear mount diff bushings correct?
EAS's Website on these for reference: https://europeanautosource.com/power...mw-e9x-m3.html
ESS Tune | Dinan CF Intake | RPi X-Pipe | Akrapovic w/CF Tips | MS Pulleys | MFactory CF Driveshaft | Alekshop Oil Cooler | WPC Bearings w/ARP Bolts | Ohlins R&T | Vorshlag Camber Plates | Hotchkis Sways | Dinan CF Strut Braces | 3-piece BBS RKII | APEX EC-7 | Brembos F&R | Recaro Profi SPG XL | Perf Elec Wheel V2 | BAVSOUND | GT4 CF Front Lip/Canards/Rear Wing | Arkym CF Rear Diffuser | Forcewerkz CF Sideskirts | Varis CF Lower Diffuser | Turner Skidplate | OEM CF Spoiler & Mirrors | Shaved Bumper | Black Roof
      01-20-2017, 06:47 PM   #9
flipmeraz
flipmeraz's Avatar
118
Drives: 10 e92 m3
Yea the purple ones are street and black race. You'll need both front and rear kits.
dj_dub876.50
      01-26-2017, 02:00 PM   #10
azndrunk74
Drives: E92 SG/FR M3
Any recommendations for the front setup to go with solid subframe bushings and powerflex purple diff bushings? Or is OEM ok? I'm specifically asking for a supercharged setup. My current plan is to replace the front lower arms, tension strut arms, tie rods with OEM since my car is a daily driver.
2009 E92 | DCT | Space Grey | Ext. Fox Red | OG Volk TE37 | ACM Mod | EAS 80mm Tips | Forcewerkz Skirts | Varis Lower Diffuser | MCarbon GT4 | M Perf. Spoiler | M Perf. V2 Electric Wheel | M Perf. CF Caps | Pedal Haus DCT Pedal & Paddles | Edition Grills & Gills | GTS DCT Tune | Red Brembo 380/380 | KWV3 | RDSport Front Sway | BW Sway Links | RE Toe Links | ECS rear arms | Bayoptiks DTM Headlights | BE Bearings | ARP Bolts | BW Track Mounts | ESS 625 | ACM P3 Gauge | BW X-Pipe | AFD Kit on E50 | 554whp/373wtq@7psi
      01-27-2017, 07:36 AM   #11
becausephilchow
Drives: 08 E90 M3
I did the Rogue Engineering Front Tension Arm Bushings (Street).
Just got it all installed, and, I can report this:
Macht Schnell Solid Aluminum Subframe Mounts - No NVH, car feels better. More "feel" from the rear end.
PowerFlex Purple Differential Bushings - There is a slight differential whine. 80KM/H+, but, it's really not that loud at all. With the radio at even a low volume, it essentially drowns it out.
Rogue Engineering Front Tension Arm Bushings (Street) - No NVH to report of really. I want to say there's a bit more road noise, but, the raod feel is definitely better. But, I also installed Ohlins R&T/GC Street Camber Plates at the same time too.
      01-31-2017, 09:09 PM   #12
azndrunk74
appreciate the feedback. look like i'll definitely be going with MS solid subframe bushings and powerflex purple diff bushings. i'm going to stick with new OEM lower control arms/bushings in the front for now.
      01-31-2017, 10:27 PM   #13
roastbeef
roastbeef's Avatar
i personally love my monoball tension arm bushings. makes the front end feel a bit more sharp.
      02-01-2017, 09:12 AM   #14
pbonsalb
Drives: 08 E90 M3, 99 E36 M3 Turbo
Even new stock front tension arm bushings will make the front end feel better. These are a subtle wear item many people don't notice until they are really bad. They are really a routine replacement item.
      02-02-2017, 02:19 AM   #15
becausephilchow
Drives: 08 E90 M3
It's a great setup. I've driven my wife and family around a few times now, not a single person has mentioned on the whine or anyhting.
That's when I know it passes the test, haha.
That being siad though, I'd just spring for new bushings if I were you. Seems a little moot just to swap back to OEM.
      02-02-2017, 04:42 PM   #16
azndrunk74
i hear you on that - i'm buying all new arms and prefer to have a new ball joint than reuse the ones on my old arms (i don't think there is an aftermarket replacement for those?). i got a lot of stuff will be done in the next month - rod bearings, engine mounts, supercharger, subframe bushings, diff bushings, and possibly bbk. i may spring to have the OEM bushings replaced with monoball in the future.
      02-02-2017, 06:36 PM   #17
Hujan
Hujan's Avatar
Drives: 2013 E92 M3
Solid aluminum subframe and PowerFlex purple diff is the winning combo, at least on a DCT car.* I consider myself very noise sensitive and this combo is 100% fine for me in all sorts of driving situations (windows up/down, music on/off, or any combo thereof).
I previously had solid aluminum subframe and delrin differential bushings and it had a lot of whine, too much for my taste, at least when cruising in a steady state on the highway.
*Anecdotally, I suspect the 6MT cars can get away with firmer differential bushings without enduring too much whine. I say this because I've ridden in two 6MT cars with solid aluminum subframe and differential bushings and did not find the whine to be as loud as my car with the delrin diff bushings.
E92 M3: MRF Velaforza | Brembo GT | KW Clubsport | BBS E88 | Recaro Sportsters
      02-06-2017, 09:38 PM   #18
Mvez
Mvez's Avatar
73
What I like to hear. I went ahead and installed the purples. No reason not to with the subframe out. V2 MPE exhaust being installed should help too.
'00 Miata - racecar
      12-02-2017, 08:39 PM   #19
buddalun
buddalun's Avatar
Drives: '12 ZCP M3 & 911
Mvez Did the purple diff bushings add noise, after all? TIA.
      12-04-2017, 01:37 PM   #20
Bartledoo
Bartledoo's Avatar
Drives: 2011 E90 M3 6MT
Did for me.
buddalun543.00
      12-04-2017, 04:24 PM   #21
buddalun
buddalun's Avatar
Originally Posted by ksteckba View Post
Did for me.
Would you have gone with OE diff bushings, if you were to do it again?
      12-04-2017, 05:10 PM   #22
pbonsalb
I used red poly 75D subframe and black poly 95A diff bushings and can hear minor whine in the 65-75 mph range in top gear on the highway. It’s tolerable. I wanted stiffer diff bushings because some have broken a diff mounting bolt or even the diff rear cover or subframe due to excessive diff movement.
Search this Thread:
Advanced Search
