Go Back   M3Post - BMW M3 Forum > M3 Marketplace > Private Sellers - For Sale / Trade / Wanted > Suspension / Brakes / Chassis / Spacers
      10-21-2020, 12:48 PM   #1
AquilaBMW
Drives: 2008 M3
DINAN E90 Stage 2 Suspension System (non-EDC only)
Sold
Hi There!
I have the option of acquiring this Stage 2 Kit for NON-EDC BMW E90 M3. Wondered if it might be of interest to anyone before it hits ole flea bay?
It comes with the following:
• Performance Spring Set
• Matching Front Bump-Stops
• Front Guide Supports
• Rear Upper Shock Mount Kit (10mm)
• Lightweight Tubular Adjustable Front Anti-Roll Bar
• Urethane Bushings
• Heavy Duty Brackets
• Adjustable Length End Links
From DINAN:
Stage 1 Suspension System
Dinan's Stage 1 Suspension System provides greater control over body roll by virtue of carefully calibrated spring rates designed to work in conjunction with the original-equipment standard or EDC shocks and struts. Dinan lowers the M3 by 1/2" front and rear for improved suspension geometry and an even more aggressive stance. Matching bump stops and replacement front guide supports are included that actually increase suspension travel by 10mm for improved handling capabilities along with surprisingly civilized ride quality. The higher spring rates, increased suspension travel and improved suspension geometry give the M3 even more grip for faster and more predictable cornering capabilities. All of the factory strut/shock system are maintained for cars equipped with this option.
Benefits:
+ Reduce Body Roll
+ Retain Factory strut/shock functionality
+ Lower Ride Height by 1/2" in Front & Rear
+ Improved Suspension Geometry
+ Increase Suspension Travel By 10MM
+ Superb Ride Quality
+ Improved Mechanical Grip In All Conditions
Stage 2 Suspension System is the addition of the Lightweight Tubular Adjustable Front Anti-Roll Bar to the Stage 1 Suspension System.
SPECIAL NOTE: For vehicles not equipped with Electronic Damper Control only. System employs stock shocks and struts.
      10-21-2020, 04:31 PM   #2
kawstik
kawstik's Avatar
Drives: E92 M3 6MT
I'll take the sway bar + end links if you're looking to split the kit.
      10-21-2020, 04:33 PM   #3
AquilaBMW
Drives: 2008 M3
Not splitting - sorry. It's a brand new kit, would sell complete as a kit.
      03-30-2021, 10:17 AM   #4
AaronI
AaronI's Avatar
Drives: e90 m3
Is this kit still for sale? I'm local
-Aaron
      04-04-2021, 02:00 PM   #5
AquilaBMW
Drives: 2008 M3
Sorry..... It's gone.
Search this Thread:
Advanced Search
