05-30-2021, 01:55 AM | #1 |
Rep 65
Missing Downshift Blip e9x m3
Car on alpine tune
Car downshift with no issues for months Was driving earlier and realised no more downshift blip in M or Non M mode, maxed on S4-5 also no diff The downshift became very quiet (i know because mine was a decatted pipe) Please advise |
05-30-2021, 04:43 AM | #3 | |
Rep 65
Tried it with different settings too no luck Recently i did installed a pedalbox but that was one week ago and everything worked fine until 7 days later |
05-30-2021, 06:35 AM | #5 |
Rep 4,336
05-30-2021, 07:35 AM | #7 | |
Rep 65
Only downshift blip is gone Anyway im wondering after removing the pedalbox should i recalibrate the pedal sensor(can this be done?) |
05-30-2021, 11:59 PM | #8 |
Rep 65
Problem solved
Removed the pedalbox and plug in Ista+, in throttle position, i see the difference in variant for pedal sensor 1&2 are 107% Reset it and car drive normally for now... downshift blip is back... |
05-31-2021, 07:26 AM | #10 |
Merlin
487
Rep 730
Drives: 2012 BMW M3 6MT w/ZCP
Me too- what does it do? Is it interfaced with OBD II receptacle ?
Thank you, Merlin
2012 E92 M3 ZCP | 2008 E90 335xi | 2008 E90 335i | |
06-01-2021, 05:25 PM | #13 |
Rep 1,855
why would you need a pedal box for this car? those are usually for other cars that need their "input" adjusted to make it seem faster. the M3 already has this feature... called "power" lul
06-02-2021, 07:22 PM | #15 |
Rep 65
06-07-2021, 06:44 PM | #16 |
Rep 564
We all know the power button doesnt add power, but a pedal box is good for 20HP...Thats why
2009 E90 M3 DCT IB Slick Top | 2017 911 Carrera White 7MT Slick Top | 2003.5 E46 M3 CB SMG | 2005 Audi A4 USP Black 6MT |
11-17-2021, 02:26 PM | #17 |
Rep 23
Hello!
I have the same problem, yesterday the car was blipping in M and Non-M mode as usual, today I noticed that it is not blipping anymore, only blips in M mode. I haven’t done any mod, the only thing out of the ordinary since the problem is that I always turn the car on and drive with the key fob in my pocket, and yesterday, for some unknown brain issue I tried to put the keyfob inside to turn the car on…. Tried to see if it was something with the S5/D5 stuff but it was in S5. I will try to see if my mechanic can check with ista |
11-18-2021, 08:13 PM | #18 |
Rep 294
Just throwing my experience/.02 out there considering I had this issue, although intermittently, not that long ago. I took my car and had a full transmission service done (fluids, filters, new gaskets,etc) and my mechanic noted that I was really low on trans fluid. I would never have been able to tell since the plastic cover collected all the leaking fluid. Prognosis came down to it being low on fluid and not having adequate pressure at times
