European Auto Source
      08-05-2015, 01:13 PM   #1
Bimmer-M3
Bimmer-M3's Avatar
153
Drives: SG M3
Window trim problem
Does anyone know how to get this gloss black again? I tried using a lot of products but nothing worked
      08-05-2015, 04:41 PM   #2
rjd598
rjd598's Avatar
Drives: E90 M3/ F30 328i
2016 BMW 328i  [0.00]
2010 BMW M3  [4.50]
you'll probably need a compound/polish to revive that
      08-05-2015, 04:51 PM   #3
dparm
dparm's Avatar
Drives: Corvette Grand Sport
I've got the same problem, FWIW. The finish is oxidizing -- you'll need something that specifically fights oxidation, followed by one or two different polishes to restore the gloss.
I was tempted to mask everything off and just lightly sand and spray it gloss black, but never got around to it.
Now: 2017 Corvette Grand Sport
Past: 2011.5 M3 sedan ZCP
      08-05-2015, 05:14 PM   #4
Bimmer-M3
Bimmer-M3's Avatar
153
Drives: SG M3
Do I need to use a buffer to do that? I don't have any currently so I am wondering if hand rubbing would work?
      08-05-2015, 05:59 PM   #5
rjd598
rjd598's Avatar
2010 BMW M3  [4.50]
there are hand polishing pads you can use. you can try to do it with a microfiber towel too, but i have no idea if it will work or not. might not be enough cut.
      08-05-2015, 08:04 PM   #6
Bimmer-M3
Bimmer-M3's Avatar
153
Drives: SG M3
so do I apply compound first by hand and if it didn't work I should switch to buffer machine? or is it polish that is going to determine?
Thanks rjd598 for the help.
      08-05-2015, 08:07 PM   #7
rjd598
rjd598's Avatar
2010 BMW M3  [4.50]
i would start with compound since you have oxidation. try that by hand then if it doesn't work you have to go to a machine.
      08-06-2015, 10:15 AM   #8
Helmsman
Helmsman's Avatar
Sweden
1426
Drives: 2011 E90 M3 ZCP
No offence Bimmer but how does it become like that? On my 4th BMW with gloss trim and they never shown anything like it. Might be worth to have a chat with the dealer about quality fail?
Cheers
      08-06-2015, 12:23 PM   #9
rjd598
rjd598's Avatar
2010 BMW M3  [4.50]
Cheers
yea i have no idea how that happens
      08-06-2015, 11:45 PM   #10
Honda
Honda's Avatar
165
Drives: BMW
Cheers
I have seen several M3's with this issue. It is quality problem for sure
      08-07-2015, 08:23 AM   #11
Helmsman
Helmsman's Avatar
Sweden
1426
Got it Bimmer. Well in that case I'd be all over the trims polishing and waxing to try keeping in in shape.
Good luck!
Search this Thread:
Advanced Search
