07-29-2016, 02:17 AM | #1 |
Rep 151
4.10s = As fast as a DCT?
I've been thinking lately. I see many videos online of DCT (modded & unmodded) cars completely destroying 6MT cars in a 1/4, 40roll on, w/e straight line situation. That is because of the gearing, correct? Anyway, would "slapping" a 4.10 FD close the gaps I see? I understand the 6MT shift will still be slower but could the gap be closed at least...
07-29-2016, 08:43 AM | #3 | |
Rep 1,256
07-29-2016, 08:53 AM | #4 |
Rep 5,483
I see a lot of vids of people who don't know what the hell they're doing with a shifter and clutch too. The big problem you can't overcome no matter what short of a new gearset in the 6MT is the 2-3 rev drop on the manual drops the car 600rpm further down than the DCT on 2-3 shifts (5500 rpm vs. 6100 rpm) and the DCT gear ratio spread is just a lot closer where it matters, though once you are doing 3-4 and 4-5 the 6MT starts to be geared just about perfectly for max accel, that 2-3 shift is a killer. But eventually if you keep going long enough the DCT will overheat or all the fluid will leak out, so there's that and if you are delimited the shorter 6MT top gear means you will eventually pass the DCT car after it shifts into the too-tall 7th at 174mph, right before you crash into a tree at north of 185 mph, assuming you haven't changed to the 4.10, in which case you'll run out of revs at 184
SYT_Shadow11479.50 FogCityM3499.00 |
07-29-2016, 09:52 AM | #5 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
i think it will help. i've seen e46m with manual vs smg and the manual with 4.10s was awesome. it's like a cheap supercharger.
07-29-2016, 10:00 AM | #6 |
Rep 10,614
DCT will shift faster than a human. Cant beat that. Gearing could make a 6MT faster in a certain limited speed range, however. Expertly driven, a 6MT is very very close to a 7DCT in a straight line, but it takes much more work to drive a 6MT.
07-29-2016, 01:47 PM | #7 |
Rep 151
Well I was doing some number crunching on the 4.10s vs 3.84 gears. So 40 roll with stock FD would be about 4700rpms (even though I feel like it's at 4500 everytime I'm at the strip for some reason...) while 4.10 FD I'd be at 5100rpms. That's pretty significant. Idk what rpms the DCT would be at @ 40 but I feel any pull about 5k is remarkably faster for the e92 since revs and power don't stop till 8500. Hopefully I can find someone with a DCT car I can do some real world testing with.
07-29-2016, 01:57 PM | #8 |
Rep 5,483
DCT and 6MT are essentially identical through 1st-2nd gearing wise, the differences start on the 2-3 shift (and obviously DCT is going to make the 1-2 shift happen quicker too)
07-29-2016, 02:33 PM | #9 |
Rep 6,771
Drives: 2016 BMW i8
DCT may be tricky to launch sometimes. That's where a good 6MT driver can gain some advantage.
07-29-2016, 07:48 PM | #10 |
Rep 8,076
Drives: 11 E90 M3 Individual
So...you are going against a car that shifts faster. So you want to beat that car by adding more slower shifts in a given distance by lowering your final drive ratio?
That really doesn't make sense.
2018 F30 320iX Melbourne Red
07-29-2016, 08:13 PM | #11 |
Rep 151
07-29-2016, 08:32 PM | #12 |
Rep 2,400
From an acceleration perspective from a dig, think the difference of 4.1 vs 3.85 would be negligible. On a track however, Turner Motorsport themselves say that going to a shorter ratio is one of the best things you can do to make an MT faster on the track to really take advantage of the gift of one of the widest power bands in existence. A lot of time is typically spent in 3rd gear, where on many tracks its a tough call to downshift into second. On long straights you pretty much have to shift in 4th anyway, so don't feel like you're really adding shifts at least on the tracks I go to..may actually subtract downshifts into 2nd. Adding more torque at the wheels at the bottom of the power band helps and the ability to tune to 8600 rpm also helps with the rpm drop. Also look at the M3 GT4 gearing: 4.1 rear diff. It's done for a reason, not to mention the benefits you get from earlier locking mechanisms and that 6th gear has a very hard time overcoming wind resistance and is basically unusable.
07-29-2016, 08:52 PM | #14 | |
Rep 151
07-29-2016, 08:54 PM | #15 |
Rep 151
07-29-2016, 09:23 PM | #16 | |
Stop the hate, get a V8
3850
Rep 8,625
It also has to do with the fact that there is effectively no drop in power between shifts. Yes, a 4.10 final drive will improve acceleration, but it will not overcome the brief period of time when you are between gears, no matter how fast you can shift. What is the reason for wanting the 4.10? Is it for stoplight racing? Are you going to take the car to the drag strip often? Do you track the car? One or more of these things? Knowing this will be the first step in deciding if you need to change the gearing (if at all) and by how much. Lego-building might not get you what you want, so help us understand the use cases.
Past: 2011.5 M3 sedan ZCP |
07-29-2016, 09:43 PM | #17 | |
Rep 151
07-29-2016, 10:01 PM | #18 | |
Rep 8,076
07-29-2016, 10:27 PM | #19 |
Rep 3,964
A set of 4.10 gears with a 8600rpm would be an awesome package, especially from a roll. Off the line you can leave to hard and just end up smoking 1st and 2nd gear.
I plan on doing this along with bumping up the rpm limit to 8600rpm once my warranty gets near the end. Then maybe a set of Shcrick bumpsticks to go along with it. Dave
07-30-2016, 11:17 AM | #20 | |
Rep 151
07-30-2016, 11:35 PM | #22 | |
3850
Rep 8,625
Okay, then you may want to start looking at generating thrust curves for the proposed gearing/tires/powerband, something I talk about in this old thread: http://www.m3post.com/forums/showpos...0&postcount=39
