11-05-2019, 07:50 PM | #1 |
Rep 90
Sad conclusion to brief experience
tl;dr - if you want to make illegal mods, then don't pass the buck. That's shitty. Own your decisions and repercussions.
11-05-2019, 08:07 PM | #3 |
Rep 10,614
This would not have cost much to fix. Buy a used x pipe, used rear exhaust and flash in a stock tune.
The seller probably sold it to the dealer as is. I would not use a dealer that does not bother to check out a car it is buying. Last edited by pbonsalb; 11-05-2019 at 08:48 PM.. |
11-05-2019, 08:07 PM | #4 |
Rep 3,408
This is an unusual post for a enthusiast forum... As you mentioned a very simple fix. If you loved the car, options, color, mileage, etc I would've spent $300 on an OEM x pipe and called it a day. Far worse problems could be lurking in a future purchase.
But best of luck in your search!
wfdeacon881105.00 |
11-05-2019, 08:11 PM | #5 |
Rep 12,726
what if you just had the dealer flash the car with the oem software and swap in an oem xpipe? if you like the car, it isn't that much to make it "legal" and pass any inspection. its less than an hour of work and completely reversible.
11-05-2019, 08:17 PM | #7 |
Rep 726
Going back to stock would've been pretty damn easy...and probably worth it if the car was otherwise what you wanted.
1) How in the world did the PPI not catch this? Even the most incompetent shop should be able to see that the car had no cats. 2) How did you not catch this? Was this the only E9x car you drove? Did it not seem the slightest bit louder? I mean c'mon man. Primary delete and mufflers add a ton of sound to these cars. 3) The fact that this car was modified probably means an enthusiast prior owner. A cat delete is not ricing the car. EDIT: saw that this was in fact the only E9x you drove. I don't know man, some better due diligence would've helped here. |
11-05-2019, 08:25 PM | #9 | |
Rep 726
I would be just as annoyed at the shop who performed the PPI... |
11-05-2019, 08:33 PM | #11 | |
Rep 726
On to something else. |
11-05-2019, 08:33 PM | #12 |
Rep 3,408
Was starting to think this was a troll. But not the case.
From your purchase post - I think you're not going to be as in love with an OEM xpipe and exhaust. Probably would've been worth riding along in an unmodified car before losing all this money and time. Might be right back where you started after 6 months... "Hi All, I have been on-again-off-again thinking of buying a 2013 M3 for the last 2 years based on a recommendation and research. Long story short, I just bought one today. Once I drove it, I was in love. OMG I have a lot to learn about it and get to know it and totally looking forward to it. I did get a PPI done and they said it looked clean. sooner than later, rear brakes, oil.... Any tips/advice welcome!! Cheers"
11-05-2019, 09:07 PM | #13 | ||
Rep 3,408
Again these are all simple fixes if you find the new dream car. But will cost a few $$$ too get those mods back. I'd prioritize low miles, clean history, and service records over frustrations around removing mods you don't like. These cars are money pits in nothing but the best way. Even with the best intentions, it's likely you'll want to make changes... Just ask the wives of this forum.
11-05-2019, 09:14 PM | #14 | |
Rep 12,726
https://www.realoem.com/bmw/enUS/sho...diagId=18_0745 then flash it with 240e software (it will cost the dealership nothing). its that simple. there isn't any acceptable aftermarket parts.
11-05-2019, 09:17 PM | #15 | ||
Rep 3,408
11-05-2019, 09:40 PM | #16 | |
Rep 12,726
i presumed your car already has a muffler. you only need that xpipe to pass emissions from what you described. the muffler should bold right up. post a pic of your exhaust and we can help you figure it out. oem rear exhausts go for about $150-200.
11-05-2019, 09:52 PM | #17 |
Rep 12,726
so its the oem muffler that has been modified? post a picture of the rear muffler tips (any brand logos).
11-05-2019, 09:57 PM | #18 |
Rep 12,726
lol. you can buy those parts for less than $500 on here easily and have them put on for $150.
if they are going to be completely stupid about it just make them buy the car back.
11-05-2019, 10:01 PM | #19 |
Rep 1,389
OP - I'm not sure if this will help, but this sounds like a 1 out of 10 (10 being bad) in terms of being screwed by a dishonest E9x seller. So so many more things are 10x worse than essentially test pipes and an OEM mod... to name a few: dumping a rod knocking car, hiding an accident with significant body damage, various oil leaks that could occur, etc.. Selling a car with this MINOR of a list of modifications is pretty much nothing in terms of dumping "cost" onto another owner unexpectedly. If you had a PPI, which any buyer should do, it would have caught this ~$300 fix, and I'm sure you could have shaved it off the purchase easily. I'm kind confused by the entire thing I just read.... you could probably trade a modified x-pipe & modded OEM exhaust for stock and made a few hundred bucks on the deal easily. :
11-05-2019, 10:04 PM | #20 |
Rep 12,726
look. i found an oem setup on here in a matter of minutes (i'm not affiliated).
https://www.m3post.com/forums/showthread.php?t=1591915 you could find something similar in your area and have it put on and get the car flashed back to the oem software. then sell your "test pipes" (thats what what you have is called) and whatever rear section you have and you'll probably break even.
11-05-2019, 10:05 PM | #21 |
Rep 1,389
Why are you using a dealer for ANY quotes for anything being done to the car? You literally might as well go to an atm, withdraw money, and burn it. Find an Indy shop that will do better work, and help you for 1/100 the cost. literally
11-05-2019, 10:10 PM | #22 | ||
Rep 1,389
scrammer421.50 |
