02-26-2019, 05:09 PM | #1 |
Rep 46
Tough Choices
Hello all,
I have been an M enthusiast for many years now, but I am finally at the point where I can afford to buy a new car at the end of this coming summer. My price range, depending on exactly how much money I can make working this summer, is most likely going to be everything up to 20-21k max, but preferably somewhere around 18-19 (leaves room for some initial mods and possibly maintenance). I have always dreamed of owning an E92 M3, but I can't seem to find one that doesn't give me some maintenance worries within my price range. That being said, there are two other cars that I'm considering, each with their own reliability problems, being the E60 M5 and the E46 M3. I'm drawn to the E60 and the E92 a lot more than the E46 because of their high-revving and amazing-sounding motors, but I am still considering the E46 because of its superior driving feel and the generally lower pricing on it. I am going to be living in the Los Angeles area for the next few years, so I am looking at DCT/SMG models due to obvious traffic reasons and my personal love for the DCT gearbox. I have done a lot of my own work on my current E39, and I plan on being able to do most of the required maintenance on my next car. Any suggestions for this specific case (specifically comparing the difference in maintenance costs for an E92 vs. an E60)? |
02-26-2019, 05:46 PM | #2 | |
Rep 203
Will you be paying cash or financing? If the former, you might be able to swing it as you won't have high car payments, and can put money away for maintenance. If the latter, consider both E92 and E60 require $200 oil changes, $1500 tires, and very high fuel costs as just your cost of keeping it on the streets. If anything does go wrong, you're looking at a hefty repair bill, even if you do the work yourself. The E46 M3 on the other hand can be found in great condition within your budget. While cost of ownership is less than both its younger siblings, it's still not cheap. As far as comparing the E92 maintenance to E60, think of it this way - the S65 V8 is the S85 V10 with two less cylinders. Very equal in terms of maintenance. The transmission however is a whole other story. The SMG in the E60 is far inferior to the DCT in terms of performance, comfort, and most importantly, reliability. They are highly prone to failure and IMO the reason why you can find E60 M5's for as cheap as they are. I am not trying to discourage you from getting into an M car, as they are truly fantastic machines, just making sure you consider the additional costs of ownership beyond simply the purchase price of the car. |
02-26-2019, 05:49 PM | #3 |
Rep 498
Drives: 2010 E92 M3
E60 M5 has all the issues of the E9x M3 and then some. The S65 engine in the M3 is essentially the S85 (M5) engine with two less cylinders. Rod bearings, throttle actuators, main bearing issues (less common), awful on gas, throw in vanos and SMG issues on top of it. The M3 DCT is much better than the e60 M5 SMG transmission.
The E9x, as many here will tell you, is pretty bulletproof if properly maintained. Some will tell you they've spent $250 on maintenance in two years. Others will tell you they've spent $5,000 in maintenance in six months (me). What it boils down... Try to get a well-sorted, well-maintained e92 M3 for mid-high 20s (really low 30s is an ideal budget but solid cars are being had for high 20s 75k mile range) and just have some cash in savings or a good credit card for a rainy day. Although I'm inclined to say sock some more money away first. Do the maintenance yourself as labor will run upwards of $120-$150/hr depending on where you live. You can save a lot... that doesn't mean parts are cheap... you'll become very familiar with the "M Tax" where bolts cost 5x as much. Familiarize yourself with FCP Euro's lifetime warranty (yes, on oil and brakes too), and plan on doing some preventative maintenance (rod bearing job is $2500 but isn't mandatory, that's a whole different beast of a topic). I wanted one of these cars for a long time too. It took me years to pull the trigger. I'm getting pounded by maintenance right now but once it's done I know I'll have years and years of shit eating grins for the cost of fuel, tires, brakes, and oil. Personally- I think, considering your budget, I'd lean toward the e46 M3.
2010 E92 M3 // IG: @commuter_blue
MRAT3D57.00 Whyte Dynamyte29.00 |
02-26-2019, 05:51 PM | #4 |
Rep 1,881
I agree, e60 m5 is probably out of your budget. an '08 e92 m3 could be a good car, and they can be had to $20k, but again if you have an issue and need to spend $2k on maintenance within a short period of time (first 3 mo of ownership) will you be ok with that? E46 m3 can be had for less, but they are appreciating and the clean ones are out of your price range. The higher mileage e46m3 could have costly repairs needed such as: vanos repair, valve adj, rod bearings, clutch assembly, rear subframe tearing from frame, etc.
In reality I probably cannot afford the e90 m3 that i am driving. But do i think about that when the s65 with Karbonius manifold is screaming, nope. For me its worth the financial burden, for others it's not.
02-26-2019, 06:19 PM | #5 | |
Rep 1,912
Drives: Here and There
02-26-2019, 06:27 PM | #6 |
Rep 2,822
TBH, I wouldn't look at any of those cars with that budget. You're just not going to get a very clean example, and will end up in a tight spot come maintenance time.
Common saying on the E46M boards over the last 5 years ... the car will cost you $30K no matter what. You either pay for it up front, or in maintenance in short order. I would get something like GTI and save up for a few more years. Soon you'll find clean sorted out cars for low $20Ks. Right now I think they're just over that, though. It's not worth the financial headache if you're really on a budget. The cars will always be around and they made enough E92s to always find clean, low mile examples in a spec you like. No need to rush it. |
02-26-2019, 06:34 PM | #7 |
mTekMods
2115
Rep 2,872
You can’t afford these cars.
Buy something within your budget, you don’t want your car to need two throttle actuators and you have to leave it parked because you can’t afford to fix it. |
MachinesWithSouls4832.50 6ixSpd5996.50 |
02-26-2019, 06:49 PM | #8 |
Rep 46
To be fair, I know how to/have the right tools to replace these. A $300 job isn't too expensive for me.
wfdeacon881102.50 |
02-26-2019, 06:51 PM | #9 |
Rep 657
the smg can be a bit of a hassle. i have a non-M e46 with it's variation of the smg transmission. the pump lasts about 60-70K miles. fairly easy DIY. but there are gear position sensors that can go out as well and the tranny has to be dropped to access them. then there's the subframe and VANOS hassles as well. great driver's car. just know what you're getting into.
02-26-2019, 06:52 PM | #10 |
Rep 12,714
if you have a low $20's budget due to financial constraints, don't get any of the cars listed. i know you're not asking for financial advice, but we can get into that if you want to.
02-26-2019, 07:01 PM | #11 | |
Rep 1,036
I do agree with what others have said, if you really only have 21k, this probably isn't the car for you. But I don't agree that you'll find clean sorted out cars in the low 20s 5 years from now. This is just an opinion though, of course
Akrapovic | AngeliBright | APEX | Hankook | IND | JRZ RS1 | Macht Schnell | Mode Carbon | Vorsteiner |
LuckiSevens227.00 |
02-26-2019, 07:12 PM | #12 | |
Rep 448
Also, find a private sale and negotiate the price - the deal I got was lucky, but the fact I was paying cash made the seller more inclined to accept a lower offer for a quick transaction. |
02-26-2019, 07:16 PM | #13 | ||
Rep 448
02-26-2019, 07:18 PM | #14 |
Rep 394
Agreed on this. Coming from two E46 M3s, one SMG and one 6MT, I can say that SMG is garbage compared to DCT; I can't stress how much you don't want SMG. Also a good condition 6MT E46 in LA is going to run you at least in the 15-20K range, and it's still going to be a 13+ year old car with maintenance to match.
LuckiSevens227.00 |
02-26-2019, 07:28 PM | #15 |
Rep 203
I do think we need some more info. We've all been quick to judge (myself included).
You say you'll have to work all summer to reach the max budget of 21k. Does that mean work all summer to make the cash to purchase outright? If so, that's very different than working all summer to afford the down payment on a 21k car. Please clarify. |
LuckiSevens227.00 MachinesWithSouls4832.50 |
02-26-2019, 07:29 PM | #16 | |
mTekMods
2115
Rep 2,872
02-26-2019, 07:31 PM | #17 | |
Rep 203
wfdeacon881102.50 |
02-26-2019, 07:52 PM | #18 |
Rep 1,389
Its definitely an expensive car for 'milestone' maintenance... the routine e9x ~80-100K mile items are pretty pricey if one isn't a DIYer. I don't have the time or tools to learn how to do things like valve cover gaskets, DCT service, oil changes, fuel breather valve, oil housing gasket, etc.. but thanks to this amazing forum of very smart M enthusiasts, I have saved myself a lot of money by being able to recognize things and identify problem areas to tackle before they become a real issue.
I actually think that a high mileage, well maintained car could be affordable on a "Budget" IF one is a wrench head and willing to do the work.. most of my repairs/PM that I've spent money on appear to be mostly time/labor cost...So if you can find a good used, higher mileage e9x and are willing to work on it yourself, I say go for it. I really wish I was more handy, but that's on my list for a future hobby when things slow down. go for it. YOLO |
02-26-2019, 08:14 PM | #19 | |
Rep 448
02-26-2019, 08:37 PM | #20 |
Rep 913
the e60 m5 with smg is probably in the top 3 bmw's ever made that you DONT want to own out of warranty!! stay away! e46 m3 with smg is troublesome as well, and prehistoric in all aspects in comparison to the DCT of the e9x...
02-26-2019, 09:15 PM | #21 | |
Rep 12,714
02-26-2019, 09:20 PM | #22 | |
Rep 46
LuckiSevens227.00 |
