07-14-2020, 05:50 AM | #1 |
Rep 787
How does the brake pad wear sensor work?
Hi guys.
Would you know how the brake pad wear sensor work? I mean, when it's normal, is there a constant current passing through it, that decreases or increases as the wear goes on? If the two sensor wires contact each other, will it damage the electronic module? |
07-14-2020, 06:37 AM | #2 |
Rep 1,069
It works by measuring resistance.It is a dual stage, so there are 2 wires in the sensor that when worn through, change the resistance values. That makes it a 2 stage warning of wear indication.
E46, E60 M5, E93 M3, F15 X5
IG - @thebimmerhaus |
07-14-2020, 07:48 AM | #4 |
Rep 1,069
No, it will not damage it. It will fool it into thinking it has full resistance. If it is already showing a brake warning, you will have to do a reset procedure though. Do a search. I can't remember the steps, haven't done it in quite a while.
jvictormp881.00 |
07-14-2020, 08:13 AM | #5 |
Rep 3,982
No, I have old sensors that I cut the wires off and bridge together. I use them when I have my track pads in, since they don't have slots for the sensors and they would probably melt at the track.
jvictormp881.00 |
07-14-2020, 09:08 AM | #7 | |
Rep 2,747
By the connector to keep them out the way.
9ers
07-14-2020, 08:22 PM | #8 |
Rep 787
07-14-2020, 08:42 PM | #9 |
Rep 1,069
I believe it is about 2000 ohms as I recall. If you are thinking that you need to add a resistor, you don't. Just connect the two wires together to complete the circuit. I personally just spring for new sensors, but have done the cheat to get me by in a jam. You may be overthinking it.
jvictormp881.00 |
07-14-2020, 08:53 PM | #12 |
Derbo Tuning
3607
Rep 3,022
IG:ruhrohz_m3
jvictormp881.00 |
07-24-2020, 10:53 PM | #14 |
Driver
2692
Rep 2,714
I found some info somewhere that indicated it was below 1ohm but greater than zero. Resetting after crossing the wires wouldn't give me anywhere near the full mileage. Perhaps having a lower resistance than new causes this? I'll order some new ones to check at some point unless somebody else already has...
jvictormp881.00 |
07-25-2020, 12:26 AM | #15 | |
Rep 2,747
9ers
jvictormp881.00 |
07-25-2020, 05:49 AM | #16 |
Rep 1,069
This-
https://www.newtis.info/tisv2/a/en/f...-right/WzRZydX And this- https://www.e90post.com/forums/showthread.php?t=981050 We have 2 stage sensors with a resistor.
07-25-2020, 01:10 PM | #17 | |
Rep 2,747
9ers
Dpc2u11503.00 |
