      02-02-2017, 04:54 PM   #1
Eminenceo3
Eminenceo3's Avatar
52
Drives: Mineral white E93
+battery cable/fuse box recall fixed. (No power issue)
What's up gang!
I finally fixed my +battery terminal issue. I was having the problem where I would try to get in my car and everything would be dead. If I had the alarm set, the damn thing would go off until I was able to open my glove box and wiggle the wire around.
There has been a lot of great information written about this problem here
-http://www.e90post.com/forums/showthread.php?t=549735
Also a really great step by step how too.
My situation didn't involve having to buy a new fuse box. It seems like a lot of people are buying the cable and box together. I'd suggest checking out your box and seeing if you need to replace both. I only needed to replace the cable.
ALSO, most people are splicing the cable at the fuse box. I'd suggest running the wire yourself to the battery. Its not as hard as all the hype claimed. BMW says you need to remove the seat and that's NOT TRUE.
Check out the link for the written how too and check out this poorly made video on my experience etc and where to run the wire so you don't have to splice the cable.
I hope this helps!
e92zero212.00
      02-22-2017, 03:11 PM   #2
crnxsc
Drives: E92 M3 ZCP
I took my M3 to the dealer and they fixed it.
There is an open recall on this.
      03-12-2017, 09:32 PM   #3
Eminenceo3
Eminenceo3's Avatar
52
You had a good dealer! Haha
      03-28-2017, 07:23 PM   #4
Lexustbs
Lexustbs's Avatar
Drives: 2011 BMW E90 M3
took my car in for service and my dealer said I had the battery cable recall too. I was not expecting that.
2011 BMW M3 Sedan
Bone Stock
      04-01-2017, 05:11 PM   #5
328inOR
328inOR's Avatar
17
Drives: 2011 E90 M3
I had mine done at the dealer 3 weeks ago. Anyone know if the passenger side of the dash would have to be removed? My cup holder was broken when I got the car back.
      04-01-2017, 06:31 PM   #6
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
yeah, it requires them to get behind the glove box
      04-09-2017, 11:44 PM   #7
Eminenceo3
Eminenceo3's Avatar
52
Yep. Its two screws... I don't know how they could have broken it.. That's frustrating!
