09-14-2018, 01:51 PM | #1 |
Rep 241
DCT Oil cooling line leaking
Hey everyone!
Looking for some guidance on replacing the oil cooler lines on a 2009 DCT trans. Noticed my return line has a slight leak and would like to replace both when I give my DCT a maintenance overhaul. It looks like I'll have to drop the entire trans to do this, but hoping I'm wrong in this assumption. Has anybody been down this road before? Here's a picture of the lines I'm talking about: https://www.bimmerworld.com/DCT-Tran...2283583-bm.jpg Thanks! |
09-14-2018, 03:29 PM | #3 |
Rep 241
I don't mind dropping the trans if I must. -- Can you remove the trans without having to pull the engine? Not sure if you can access the top of the bell housing...
Any guides on how to actually replace these lines once you can access them? Are they compression fittings? |
09-20-2018, 11:38 PM | #4 |
Rep 234
are you sure they aren't leaking at where they fit into the housing near the filter cartridge? Or is it at top? If its near the cartridge its pretty easy, as you can pull the lines out and put new o ring seals and pop them back in.
09-21-2018, 09:50 AM | #5 |
Rep 241
Thanks for the heads up to this!
