      09-19-2018, 08:37 AM   #1
RM3NIAN
RM3NIAN's Avatar
Drives: E92 AW M3
Is it Safe to Tow in Parking Mode?
Car has been dead in my garage for a couple weeks and I think I'm ready to throw in the towel and just have it towed, but now I'm not sure if it can be safely towed. Is towing the car while it's still in P mode safe (DCT)? The car moves when the e-brake is released, but is it still safe? I can't engage any gears with the battery being dead.
Thanks.
AW E92 M3 | Karbonius Carbon Fiber Intake l Remus Race Exhaust /w Fabspeed Xpipe | TTV Lightweight Flywheel |
      09-19-2018, 08:41 AM   #2
SYT_Shadow
///M Powered for Life
SYT_Shadow's Avatar
11480
If it is in P it engaged the parking brake and the car won't move
If you say you can move it then I guess the battery being dead means it automatically releases it
      09-19-2018, 09:01 AM   #3
bgp001
bgp001's Avatar
13
Drives: E90
You need to manually disable parking brake. It's easy, follow this thread
https://www.m3post.com/forums/showthread.php?t=1123434
      09-19-2018, 09:33 AM   #4
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
if a tow truck comes out, can't you also jumpstart the battery?
2008 E90 M3 / LCI trunk + euro tail swap
Production date - 2008-04-22
      09-19-2018, 12:56 PM   #5
RM3NIAN
RM3NIAN's Avatar
Drives: E92 AW M3
I tried charging it with a battery tender and tried jumping it with a friend's car but both were to no avail. Would a tow truck have something I don't know about?
      09-19-2018, 01:03 PM   #6
KwlAznKid
KwlAznKid's Avatar
354
Drives: BMW/MERCEDES/PORSCHE
yes, follow that, do not tow it in P
BMW E93 M3 / Mercedes Benz W209 CLK500
BMW E64 650I(sold) / BMW E92 328I(sold) / BMW E46 M3(sold) / BMW E92 335I(sold)
Porsche 996 911 C2(sold) / BMW E46 325CI(totaled)
      09-19-2018, 01:34 PM   #7
msan
Drives: 2011 E90 M3 / 2012 X5 35i M Sp
I'm pretty sure your car has the issue with the battery cable connection to the fuse box behind the glove box. You should tow to a BMW dealership and have them address the battery cable technical service bulletin. They should fix it for free under that TSB.
Also before you tow, you need to lift up/remove the dct knob leather cover/boot and use a screwdriver or stick to move it into neutral.
      09-19-2018, 01:57 PM   #8
jra85
M3NTAL
jra85's Avatar
Drives: 2011 E92 M3 ZCP
It's possible a failing EDC module is causing excessive battery drain if that was never replaced on your car. That's what had happened to mine and I had to get it flatbedded to the dealer to repair (that was my thread that's linked above asking how to put DCT into neutral with a dead battery).
      09-19-2018, 05:02 PM   #9
Scharbag
Scharbag's Avatar
Drives: 2011 E92 M3
2011 BMW E92 M3  [0.00]
http://queensroadsideassistanceny.co...s_service.html
Or make sure the tow truck driver uses dollys on the rear tires.
      09-19-2018, 05:57 PM   #10
M43S7RO
Drives: Jerez Black E92 M3
Do not tow in Park. Read the owner's manual, it describes how to get it into neutral.
aFe Stage 2 Intake | BW Race X-Pipe | UUC Corsa Exhaust | Alpine MS Tune | Brembo GT
kyippee1073.00
      09-19-2018, 07:02 PM   #11
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
Pop open the DCT boot with a non marring flat tool
Grab a phillips screw driver
Locate plain looking cover, you can flip it over and it should expose a lever looking thing where you insert the screwdriver into the hole and lever it towards the rear, as if you're upshifting.
Now the car's in neutral and the computer will tell you
