      03-01-2019, 09:38 AM   #1
Raek
Raek's Avatar
Drives: 08 M3, '17 Macan GTS
RDC Module in 2008
Hey, guys...
So, I had TPMS coded out last night, but still need to undo the RDC module. I was under the impression that the attached picture is the module (white connector), but I'm still getting a TPMS warning come up after unplugging it.
Does the whole unit need to be removed from the vehicle as opposed to just being unplugged?
Thanks!
Sike! I found it. My trunk is kinda complicated to work on with the air ride stuff in there, so I didn't pull back the carpeting enough to see the RDC.
Delete at will, moderators!
I did a lot of things to it.
      03-01-2019, 09:42 AM   #2
tdott
Drives: M3
Did you following all the coding in this thread?
https://www.m3post.com/forums/showth...ght=FTM+coding
If you don't do everything you will still get errors.
      03-01-2019, 09:45 AM   #3
Raek
Raek's Avatar
Had it done by BPM sport, so I know it's all good. I think I may just have the wrong plug unplugged.
