      11-11-2020, 03:39 PM   #1
zhan28
zhan28's Avatar
Drives: 2010 M3 sedan 6MT
EDC function not working after trying to code ZCP mapping to non-ZCP m3
Hey guys, looking for some help. Was trying to code my 2010 e90 m3 non-zcp with edc bilstein b6 to zcp shock mapping but something happened along the way where my edc is now stuck only in one firmness regardless if I put it in comfort or sport mode. The edc light on the three button control will light up if you push it but no change in firmness.
Furthermore, hitting the M button does not change the firmness setting from comfort to sport or normal as selected in the mdrive. Basically all it does is change the servo and the throttle response.
I noticed immediately after when things went wrong that I no longer had a EDC ecu module show up in NCSexper when I go to select ecu. So I checked FA and vo coded back $2vf, which brought back the edc ecu, and I can also manipulate the edc ecu module as well. But even after I try to code the edc to stock via the VO in ncsexper mode, the problem persist and I still do not have actual functioning EDC. Any insights? I'm willing to reset everything back to stock, my worries is that I no longer have the original VO profile of my car or something.
Thanks in advance for any advice!
      11-17-2020, 07:54 AM   #2
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
update the VO for edc then code the CAS, FRM, and edc module in that order.
G-Power Supercharged
zhan28109.50
      11-21-2020, 10:44 AM   #3
zhan28
zhan28's Avatar
This worked. Thank you! Zcp shock mapping now properly coded with bilstein b6 edc and h&r. Difference is subtle, but firmer in all settings. Biggest difference is the car seems more settled when going over bumps and breaks at speed, which actually makes a huge improvement to handling.
      01-17-2023, 09:53 PM   #4
GinTonic
Hi guys, I'm having a similar issue trying to code ZCP EDC after installing swift springs. Looks like all the 9005 lines I changed to 9230 are reverting back to 9005 except under one of the settings. What does updating VO mean and how do I update VO?
Tuukka1.50
