06-09-2020, 09:36 PM | #1 |
Rep 934
recommended suspension upgrades to accompany KW clubsports
I recently purchased a car with KW Clubsports, and absolutely no other suspension modifications. The car has ~ 95,000 miles, so I would like to go through the process of refreshing / upgrading the rest of the suspension to better compliment the KW Clubsports. I'm building the car around daily driving / hard driving in the canyons & the occasional track day.
What would you guys recommend? So far, I've read that it's important to install adjustable front, and rear sway bar end links to eliminate pre-load in the sway bars caused by lowering the suspension...is there any truth to that? |
06-11-2020, 08:39 PM | #4 | |
Rep 934
06-11-2020, 10:01 PM | #5 |
Rep 1,523
monoballs will tighten up your steering and you will feel more connected to the road. It's "almost" got the same affect as the solid rear subframe mount, but instead its in the front.
06-15-2020, 09:56 PM | #6 |
Rep 934
Here is my list so far,
Front & Rear Hotchkiss Performance Sway Bar Kit Turner Motorsports Thrustarm Monoball upgrade kit (pre-installed) Fall-Line Motorsports E9x M3 Rear Camber shim kit Fall-Line Motorsports E9x M3 Toe Link kit Fall-Line Motorsports E9x M3 Front & Rear Sway Bar end link kit Fall-Line Motorsports E9x M3 Rear upper control arm set Future Classic E9x M3 Reinforced Trailing Arm set Future Classic E9x M3 Trailing Arm bearing set Macht Schnell Aluminum Solid rear subframe bushing kit Macht Schnell Aluminum Solid rear differential bushing kit SPL Front Lower control arms E9x M3 SPL Front tension rods E9x M3 SPL Bumpsteer adjustable tie rod ends E9x M3 Let me know if any of this stuff is unnecessary / overkill..! Wont be cheap aha. |
06-16-2020, 12:38 PM | #7 |
Rep 108
I got:
M3 E92 ZCP LCI
06-17-2020, 10:20 AM | #8 |
Rep 1,366
Personally, solid subframe bushings probably aren't worth it if you're not heavily tracking the car...
I ran my KW's with stock everything for awhile and it was just fine. Recently added a bigger Hotchkiss front sway-bar for some more balance and that is a nice upgrade. (don't forget to get shorter end links for the sway bar) If anything next I'll be refreshing everything with poly bushings, but no need to go crazy! All the parts listed are some serious track-ready stuff. If you want it, go for it, but thats a very pricey list just for canyon runs.
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
911r891.00 BMWSpeedFreek31.50 |
06-17-2020, 10:35 AM | #9 | |
Rep 1,881
Also, this car is going to drive like a full race car if you do all of this. Street driving is going to drive you crazy, every single imperfection on the road is going to be felt, and the rear end will have NVH from the solid diff bushings.
06-17-2020, 04:50 PM | #10 | |
Rep 934
I’m used to driving track prepped cars on the street - however has this is a four door with DCT (and my daily) id like to keep some street-ability. At the moment I’m just planning on doing the hotchkiss swaybars, fallline front & rear sway bar end links & the fallline toe link kit to accompany the KWs, as a compromise. |
06-18-2020, 06:05 AM | #11 |
Rep 1,027
Definitely do it in phases. I think the few must haves people recommended will give you 80% of the improvement of that giant list for a lot less than all of it would cost.
That said, I have a very similar setup on my car and it's still very streetable to me. It's almost my weekend today and I came from a S2000 so I do think my tolerance for NVH is a lot higher than average before it becomes obnoxious.
Steve::::2012 AW E92::::IG - @sjs0433
911r891.00 |
11-10-2020, 03:55 PM | #12 | |
Rep 1,366
How do you like the Millway camber plates? Could you post photos of how they look inside the top mounts? They advertise the ability to get -4 deg of camber and I'm curious to see how that might look, even if you car is at a lower setting a visual would be a huge help! Thanks
11-13-2020, 02:59 AM | #13 | |
Rep 38
I would say that list of upgrades is overkill for the street. Likely, you will not reap the benefits that they will bring. |
11-15-2020, 03:43 PM | #14 | |
Driver
2692
Rep 2,714
I noticed a big difference on my first street drive after doing solid subframe mounts and poly diff mounts.
11-15-2020, 06:01 PM | #15 |
Rep 4,164
Front monoballs give sharper turn-in and makes the car more stable under braking. But it's not as huge a difference as rear subframe solid bushes give.
11-16-2020, 06:09 AM | #16 | |
Rep 1,027
I've even considered removing some of the SPL arms on my own car as it's a mostly street car and if anything they add complexity to alignments/setup. More ways you can do it wrong than right.
11-22-2020, 02:56 AM | #17 | |
Lt Col. …who can’t wait for his next track day!
32
Rep 227
Requesting a few more details on your setup...(ie. Are your Clubsport 2way or 3way? Endlink lengths? etc!)
•SOLD - '08 M5 Sepang Bronze/Full Merino leather/ Exec Pkg/HUD/SMG/H&R/DINAN/Coded
•'12 E92 M3 Space Grey/M-DCT/ZCP/ZPP/DINAN/ACM Test Pipes/BPM StageII Tune & Coding/M Perf Exhaust, Race seats, Alcantra V2 steering wheel, gloss grills/ModeCarbon GTS wing/GTS DCT Tune, CF int trim, door sills/LUX H8 V3/CSF race oil cooler/Trackspec hood vents/GT4 Rep CF splitter & rotor ducting/Hawk DTC60/KW CS 2way NR/B'world/Hotchkis/Eibach/Apex |
Kelse921131.50 |
