04-30-2020, 09:07 PM | #1 |
Save the manuals!
6015
Rep 6,745
Re-upholstering Recaro Sportster CS in Fox Red with heating.
Full write-up is linked on my blog here:
https://6ixspeed.com/2020/05/13/custom-recaro-cs/ Finally got these bad boys installed! Huge shoutout to AMX Performance (https://amx-performance.com) aka Recaro Max for supplying the covers in early 2019. The workmanship is fantastic, with perfect seams and 100% original quality leather. The covers come with the original Recaro attachments for a complete factory swap without the use of hog rings or any custom work. Shipping from Poland was very quick and the parcel was carefully packaged. He even offered some customer support for the questions I had going along with the DIY process despite having no obligation to do so. I cannot praise AMX’s products enough. I also bought aftermarket heating elements in a quest to integrate them with factory center console heating controls. Nowadays AMX sells the OEM BMW heating elements for a complete PnP solution with factory controls. Parts Required
What I Did I removed the stock black covers on the Sportster CS seats and replaced with AMX supplied covers. I went with OEM Fox Red hide, embossed ///M logo in the headrest, and a ///M tricolor motif in a nod to the E36 M3 Vader seats I always lusted for back in my E36 days.
End Result No errors, no warnings, heating works great and the seat belt butlers still deliver the belts. I noticed a drop of approx. 2” from the factory seats. The entire assembly with the Sportsters, heating elements, wiring, sliders, Planted floor mounts, and seat belt tensioner weighs 48 lbs. The entire factory seat assembly including all controls and tensioner weighs 65 lbs, for a weight savings of 17 lbs/side. Not bad! Notable Items
The Original Plan Initially I wanted to use the aftermarket elements with factory controls for 100% OEM integration. I wired in a NTC thermistor into the cushion element’s connection as per TIS’ schematics and used OEM connectors to plug into the smaller/base underseat module. This would not work properly, and the circuit would shut off after about 3 minutes. The reason being the thermistor I was using was not enough with the resistance values of the aftermarket elements compared to the stock setup. The power differentials were not within range of the stock PWM modulations. Trying to reverse engineer this with aftermarket elements and a calculated NTC thermistor value is beyond my scope of understanding, and ultimately not worth the trouble. If I had to do it again, I would simply buy the OEM elements from AMX. Unfortunately in my case, by the time I had assembled the covers with the heating elements in summer 2019 there was no factory solution being offered until just a few months ago in 2020… C’est la vie.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc Last edited by 6ixSpd; 05-13-2020 at 11:15 AM.. |
14
m3_tristan266.50 //steve\\1074.00 BlueM3Wagon855.50 Silos555.50 wyatth3548.50 derbo3608.50 BayE301341.00 javarithms193.50 Aktavate245.50 acarr6407.50 Kelse921131.50 B8bydesign680.00 mjn771072.50 WagonR293.00 |
04-30-2020, 09:28 PM | #2 |
Admiral
930
Rep 3,886
Very nice! I documented my DIY of the covers I got from AMX as well in my build thread!
https://www.m3post.com/forums/showpo...&postcount=110 Definitely top notch quality and the price is well worth it. Stock seats gave me major back pain. Being in SoCal heated seats weren't really necessary but very cool that you added them to your setup! I still need to heat gun a couple wrinkles from mine. In regards to the BK mounts with OE sliders, they don't drop the seat height at all which is the main reason I opted for different mounts. Enjoy em in good health!
2020 FORD RAPTOR 2014 F15 X5 | M-SPORT SOLD 2011 SG E90 M3 | 2008 AW E90 M3 | 2004 E46 M3 Last edited by M3ANMACHINE; 04-30-2020 at 09:40 PM.. |
05-01-2020, 07:50 AM | #5 |
Rep 1,027
These look absolutely amazing! Wrinkles in nice new leather covers are often the one thing that tends to make what should be nice replacements look terribly cheap. I'm glad to see the quality looks spot on to OE or better. And I love the tri-stitch color touch on the seat back.
6ixSpd6014.50 |
05-01-2020, 10:59 AM | #7 |
Derbo Tuning
3609
Rep 3,022
Kudos!
I will most likely buy the airbag/heat set from AMX in the end.. :X
IG:ruhrohz_m3
6ixSpd6014.50 |
05-05-2020, 06:58 PM | #10 | |||
Save the manuals!
6015
Rep 6,745
Thanks gents!
And shame to hear the BK mounts would negate most of the benefits of dropping the seat height I guess Planted remain the best ones so far from that aspect. Quote:
05-09-2020, 05:04 PM | #17 | |||
Rep 4,567
Also, what does the seat position sensor do? Quote:
'09 E92 M3: Space Gray, Black, Carbon Leather | ZTP 2MK ZPP 2MT 6FL | link 1 / link 2
Mods: M Performance exhaust | ZCP retrofit | Euro airbox | GTS DCT flash | JPN 240 ECU flash | Euro LCI taillights | CRT lip | OEM alarm retrofit | Space Gray bumper plugs | BMW Performance: Mk. II spoiler / Mk. II non-electronic steering wheel / mirror caps / front grilles / side gills / intake louvers / emblem |
05-09-2020, 08:02 PM | #18 |
Admiral
930
Rep 3,886
If coded properly, they should theoretically deploy regardless of an occupant being in the passenger seat as opposed to On or Off depending on if someone is sitting in the passenger side.
6ixSpd6014.50 |
05-10-2020, 11:43 AM | #19 | |
Save the manuals!
6015
Rep 6,745
The side airbags in the doors are untouched. It's the ones in the seat bolsters that are coded off because most aftermarket seats do not have them and thus trigger SRS errors. Correct
05-10-2020, 06:38 PM | #20 | |
Rep 4,567
05-10-2020, 07:00 PM | #21 | |
Derbo Tuning
3609
Rep 3,022
BMW performance ones have seat airbags and Recaro sells a Sportster with airbags but outside of North America. AMX does sell a solution that retains the airbags and plug n play. You will still need to code out the OC3 mat since they don't have it (or hack a stock seat for it to retrofit).
IG:ruhrohz_m3
6ixSpd6014.50 |
