10-03-2018, 03:53 PM | #1 |
Rep 548
Drives: 2011 E90 M3 ZCP
Rod bearing inspection after replacement?
Forgive me if this has been covered before, but I'm a new E90 M3 owner and this whole rod bearing thing has me spooked. My car is a 2011 with 25k miles, so I'm not too worried just yet.
My question is, has anyone pulled out the bearings after replacement to inspect and make sure this whole thing isn't reoccurring? You can find a billion posts of the original bearings being taken out and shown how horrible they are. But you don't see any posts about anyone taking out the BE bearings (for example) after 20-30k miles. If those posts exist, then I haven't found them. |
10-03-2018, 04:48 PM | #2 |
Rep 498
Drives: 2010 E92 M3
I second a request for information on this. BTW, I'm a new M3 owner too (2010 M3, 75k Miles, 9 days or so) and the rod bearings have me in full-on stress mode right now, thanks internet.
I just haven't had the balls to actually start another RB thread around here But I've wondered the same thing myself. 1. Is the issue with the actual rod bearings? Or is it with the crankshaft and/or connecting rods? 2. If it's the crankshaft or rods, do the upgraded bearings have any difference over stock that mitigate the problem?
2010 E92 M3 // IG: @commuter_blue
10-03-2018, 07:19 PM | #4 |
Rep 11,665
oil sample testing tells you what you need to know.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
10-03-2018, 11:12 PM | #5 |
Rep 2,359
Mileage is irrelevant as it all depends on how the shells were torqued down/journal clearance variance during the early build stages. If you can't confirm the work done, I suggest you do it asap.
There were some who pulled out after doing rod bearing jobs with BE and VAC/WPC and they looked good as new it's likely a factory related issue.
Pass me if you can.
cjm41752.50 |
10-06-2018, 10:36 AM | #7 |
Rep 11,665
I agree they know their stuff
But they don't have magical powers that they can tell bearing condition of an operating engine without a tear down. Bearings once replaced have lead (for LCI cars) that can be tracked with sample testing. Oil sample testing has already saved one engine for me.
10-06-2018, 12:20 PM | #8 |
Rep 1,254
Once you replace your bearings, taking oil samples from that point forward, w/ the baseline as a starting point, might be more "telling" than simply doing a single analysis on your factory bearings and thinking you have a clean bill of health.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
10-08-2018, 04:27 AM | #9 | |
Rep 743
10-08-2018, 06:15 AM | #10 |
Rep 10,557
I don’t think any failed engines have had oil analysis every change from new. That data would be useful. A report here and there or reports starting once the car is older and has some mileage won’t be as useful.
inTgr8r2421.50 |
10-08-2018, 08:19 AM | #11 | |
Rep 11,665
With OE bearings on LCI cars I agree, testing is a waste of time and $
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) Last edited by inTgr8r; 10-08-2018 at 08:29 AM.. |
10-08-2018, 08:27 AM | #12 | |
Rep 11,665
It needs to be done consistently to establish a trend. Unfortunately with LCI cars there's no point testing due to no lead in the OE bearings. Thats why I did my bearings right after I bought it and with only 18K miles on it. Now I can establish a trend with every oil change over time.
10-08-2018, 10:02 AM | #13 | |
Rep 743
Edit: Sorry I misunderstood that you mentioned AFTER RB replacement. Yes you’re right. |
inTgr8r2421.50 |
10-16-2018, 07:08 AM | #14 |
Rep 548
I guess what I was interested in is seeing pictures of rod bearings after being replaced.
I'm speculating that the clearance could be an issue when the engine is factory fresh which causes those initial scoring marks. It's obviously wearing down which should increase the clearance. What I'm saying is, maybe the bearings wear very shortly after the engine is new and there isn't a progressing problem after that? Like the bearings at that point and then with 50k more miles look the same. Again, this is just speculation and I have no idea what I'm talking about. :-) |
10-16-2018, 07:38 AM | #15 | |
Rep 12,714
10-16-2018, 11:14 AM | #16 |
Rep 10,557
Only a few changed bearings have been pulled so far. The number of examples should grow as some decide changing is periodic maintenance.
The idea that the problem occurs early and stops has been floated before, along with many other theories. It is possible but no one knows. Engines have failed with low miles and high miles. And most engines with low and high miles are running fine with original bearings. Recommendations can be made to be proactive and to do nothing. You have to make up your own mind. |
10-16-2018, 12:07 PM | #17 |
Rep 548
Thanks for the info!
10-16-2018, 01:19 PM | #18 |
Rep 10,557
I changed mine in 2014 when my extended warranty expired. That was my decision based on all the evidence I had — mostly what I read here. Had 60k then, about 93k now.
10-16-2018, 01:51 PM | #19 |
Admiral
930
Rep 3,886
False. Plenty of people have had failures right after a "good" oil sample result.
10-17-2018, 12:46 AM | #20 |
Rep 12,714
i would disagree only because once these go- they go without any warning. you could graph your lead counts on the '08-'10 bearings since new, but there is no number of parts per xxx that is going to indicate you should change- you're just going to know the end is near.
