06-02-2022, 04:04 AM | #1 |
Rep 40
Carbon Roof - Blistering!
Hello,
Has anyone ever experienced carbon roof blistering? I have attached some photos. Would really love to fix this up. Unsure what the process is? Never worked with Carbon before. Any advice appreciated. Thanks |
06-02-2022, 05:02 AM | #3 | |
Rep 40
It sleeps 100% of its life in underground car park. Seldom does it get left in direct sunlight with exception to driving it about. I am however based in Middle East, so it hot and sunny all the time. 85f in winter and 125+ in Sumner. I expect its the heat that caused it. The roof is very hot after a 30min drive I really hope it can be sanded down and just clear coated. Or even sanded smooth and then a carbon fibre wrap put back over it. |
06-13-2022, 11:54 AM | #5 |
Astronaut
514
Rep 732
Had this issue on my car due to a reflection of sunlight bouncing off my neighbor's window. However, my damage was much worse than this.
Tried going through insurance which was a nightmare, so I found a competent body shop to handle the issue. The roof is epoxy coated. The process is to remove that old coating, either scraping or high pressure air. Once that's removed, you prep the roof by sanding, and then re-coating the roof with 2-3 coats of clear coat. I had the clear coat tinted and not only does the roof not have anymore damage or yellow-ing, it literally looks brand new.
Instagram | @undisclosedm3
"Never think that you are above taking out the trash." |
06-16-2022, 05:14 AM | #6 |
Rep 17
I think it's poor quality work. In any case, the quality of the roof had to provide for high temperatures, or at least have a warning. But it is foolish to produce such roofs that are sensitive to temperatures.
Be that as it may, if this bothers you, you need to look for a master who will remove it with a cutter and tighten it with a film in a new way |
kyrix1st2366.50 |
06-16-2022, 06:03 PM | #7 |
Rep 5,506
You will need to have the existing clear coat removed and then re-clear coated. A car body repair paint shop can do this.
Auto Detailing Enthusiast!
06-22-2022, 08:00 PM | #8 | |
Rep 2,362
Pass me if you can.
