      09-11-2021, 10:53 PM   #1
Alecb0929
Alecb0929's Avatar
Drives: 2011 E92 M3 Competition
Exterior door handle comfort access function is no longer working, suggestions?
Just noticed a few weeks ago that my driver side exterior door handle isn't functioning properly but the passenger side functions completely normally.
Clearly the handle needs to be replaced, but I am not sure if I need to purchase a brand new OEM part or if a used part will work instead. Also, I've read the new ones need to be painted, so I'm not sure how exactly that should be done if I go that route.
Any suggestions would be great!
      09-12-2021, 05:10 AM   #2
NascaBmw16
NascaBmw16's Avatar
Drives: M3 E90
Before you do anything, check and replace the fuses,even know they look fine,just replace them and go from there.
      09-21-2021, 02:52 PM   #3
Helmsman
Helmsman's Avatar
Sweden
4470
Drives: 2011 AW E90 M3 ZCP
My drivet side comfort access stopped working, also noticed it was a little warm so clearly a short cut. Don't believe its possible to repair but not too expensive to replace with new. Dealer work incl paint, $350 ish, done.
      09-24-2021, 10:40 PM   #4
jun_e92
jun_e92's Avatar
141
Drives: 2011 E92 M3 ZCP
The comfort channels on the left and right sides of my car have been changed, and they failed at different times during the year. Go to eBay to buy a second-hand one, exchange it for $49.05 on the right and $34.92 on the left, and return to the comfort mode.
      09-24-2021, 10:46 PM   #5
Alecb0929
Alecb0929's Avatar
Do the new handles have to be programmed or is it simply plug and play with any used one?
      09-24-2021, 10:48 PM   #6
jun_e92
jun_e92's Avatar
141
This is disassembling the left and right ones that don’t work。
      09-24-2021, 11:02 PM   #7
jun_e92
jun_e92's Avatar
141
Just plug and play, and it can be completed in ten minutes. 2007-2013. 328i.335i M3 (E9X),
