      06-28-2019, 08:40 AM   #1
ichy
Drives: e90 m3
Coding out EDC
Installing my kw club sports this weekend and wanted to see if there was some step by step instructions on coding out the edc. A friend of mine has the programs on his laptop but would need to know the steps in doing it. Any walkthrough would be great. Thanks in advance!
      06-28-2019, 01:18 PM   #2
derbo
Derbo Tuning
derbo's Avatar
3609
Drives: BMW M3
If you search, its out there. :P
## Code out edc
1) Disconnect EDC module. It's located on the passenger side rear quarter panel, accessible through the trunk. It's the module with 2 connectors (white and blue). Can't miss it.
2) Remove option $233 from Vehicle Order in CAS using FA_write; then change ECU and FA_write the NFRM.
3) In KOMBI set EDCK_ALIVE_ZAEHLER to nicht_aktiv and EDCK_ID_MONITOR to nicht_aktiv.
4) If you have the first gen idrive (08) in CAPPL set EDC to nicht_aktiv. / if you have the later idrive in CIC set EDC_CIC to nicht_aktiv
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
SF Bay Area: DM For coding services
ebisu81079.50
ichy24.50
tsk941522.00
GcD128.50
