03-19-2017, 08:04 PM | #1 |
Rep 122
Noise after 43/45 MPH? Video attached
Well here is one of the other issues I've been having. When I drive and speed reaches about 43+ mph to around 60-70 I'm hearing this whining noise. If you watch the video you can hear it especially towards the end. Those periods when it comes and goes in the video is I let on / off the gas pedal. Any thoughts? Noise happens only when pressing on a gas pedal. I could put in neutral on 80 and let it slow down to that 40-60 bracket and it wouldn't make any noise. I was thinking maybe drive shaft? Something maybe with a flywheel? Any thoughts?
03-21-2017, 12:57 PM | #4 |
1006
Rep 1,653
My '08 E90 M3 makes the exact same noise under the same conditions. The only information I could find on it was either that it is a "normal //M sound," or possibly a differential input shaft bearing.
I'm going to flush the diff fluid first to see if that does anything. -Anthony |
03-21-2017, 05:18 PM | #5 | |
Rep 122
03-21-2017, 05:50 PM | #6 |
Rep 1,017
Drives: 2010 E92 M3 6MT
Almost sounds like the whine you get with solid rear diff mounts. Could be a bushing is shot in your drive line, will come and go at diff speeds and stop when you let off throttle.
03-22-2017, 08:10 AM | #7 | |
1006
Rep 1,653
Wishing you the best of luck diagnosing your sound! |
03-23-2017, 12:05 PM | #8 |
Rep 13
I have the exact same sound on my 2012 M3 with only 33000 miles on the clock. Went on a testdrive with a bmw tech and he was pretty certain that sound came from a faulty wheel bearing, which they replaced. The noise still remained and after further inspection they came to the conclusion that its coming from the differential. I'm getting a new one on warranty and will report back if the noise is gone. Sure hope they are changing the mounts too, if not i might consider paying for them myself..
03-23-2017, 06:38 PM | #9 | |
Rep 122
03-28-2017, 12:32 AM | #10 |
Rep 330
Mine makes the same sound 85k on the clock and I'm sure it's diff related since it only does it under 3k so it being load related makes it sure it's going to be the diff
04-06-2017, 11:15 AM | #11 |
Rep 13
Just a quick update, i'm still waiting on my new diff. My dealer had some staff issues and i've been rescheduled for the 18th. I also told my dealer to replace all diff related bushings as well. This will cost me about 250 in parts and labor but i think it just makes sense when replacing the whole differential. Will keep you guys updated!
04-08-2017, 12:26 AM | #12 | |
Rep 122
Thank you! |
04-20-2017, 11:02 AM | #13 |
Rep 13
Ok guys, new diff is in, noise still remains. My guess is the left hand side drive shaft or the joints are bad. I'm pretty sure because everytime i corner to the right the noise disappears while cornering to the left makes it louder. Its the only part that comes to mind that might react like that to axial movement .
04-20-2017, 05:03 PM | #15 | |
General
63411
Rep 24,687
04-22-2017, 05:17 AM | #16 |
Rep 13
Got a new appointment at my dealership. They'll replace the passenger side wheelbearing as well now. God knows why they didnt consider replacing both at the same time. I shouldn't complain though, got a shiny new differential for free. Will report back when its done.
05-07-2017, 03:18 AM | #17 | |
Rep 122
