BPM
      05-03-2015, 04:31 PM   #1
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
HELP with engine code P0358 or 275A
Hey guys need a little help here I did search for code and could not find it kept coming up with "no results found"
Background.. Just installed an ESS 625 kit over the weekend was a pain in the ass because it was a used kit and few bolts didn't make it so had to take a few trips to the parts store.
Car is all bolted up and it starts but it is throwing DCT code 275A through the ESS Eflash program and a P0358 through an OBD scanner.
Both the codes are related to cylinder 8. I did nothing related to the spark plugs what i have done in order to try to fix the problem is swapping coils and plugs with cylinder 2 and nothing it is still throwing the same code.
Any advice or experience on this?
Thanks in advanced.
Performance
ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe
Looks
M colors grill - CF trunk - Sapphire Blue Forgestars F14
      05-03-2015, 05:06 PM   #2
regular guy
Drives: Sprint car
http://www.m3post.com/forums/showpos...&postcount=129
      05-03-2015, 05:06 PM   #3
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
Checked for spark at cylinder 8 and there is spark. So its not the coil
ECU was already tuned with E-flash for the supercharger.
Performance
Looks
      05-03-2015, 05:08 PM   #4
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
Originally Posted by regular guy View Post
Oh thank you I missed that one.. Search noob i guess,
It says to fix it replace the coil but i swapped it out with cylinder two's coil and the problem is still at cylinder 8
Performance
Looks
      05-03-2015, 05:16 PM   #5
regular guy
Drives: Sprint car
You didn't miss it...I just added it for you.
      05-03-2015, 05:27 PM   #6
CIFUM3
CIFUM3's Avatar
Drives: 08 E92 M3
Oh right. Lol well thank you.
Performance
Looks
      03-24-2019, 01:52 AM   #7
MrPrena
MrPrena's Avatar
Drives: BMW Hyundai Nissan
Had same issue P0358 or 275A
I replaced the spark plug, and swap out the coil , and I also had problem with Cyl 8 (275A). Any updates? Solutions? thanks.
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
