11-06-2017, 05:17 PM | #1 |
Rep 769
Oil fill cap leaking
****Update****
I've been neglecting this thread way too long, finally remembered to post an update (car is at 161k miles now). The solution posted below did work for me (with a slight variation). It look 2 applications (I think I just didn't put enough the first time), but what worked for me was using Permatex Ultra Black Gasket Maker. Liberally apply on the bottom of the oil cap where it meets the valve cover opening and then screw it on and let it set for 24 hours (or more if possible). When you first take the cap off after doing this fix (to change the oil or top it off), the cap will actually be sealed to the valve cover with the gasket maker, but when you put it back on it will still keep oil from leaking due to the extra gasket material under the cap. The only leaks I've seen are very slight leaks after running the car very hard for a 20+ minute session during 95+ degree track days (which is allegedly normal). This was done with the old style cap (I think?) - it's the one that does NOT have the raised "bar" in the middle for turning it, it just has the "nubs" around the outer edge. ****Update**** About 2 months ago, I noticed my oil fill cap was starting to leak a little bit. Being a 7 year old car with 125k miles and some track wear, I wasn't too surprised. I checked the forum and there wasn't much aside from replace the cap - which at about $14 is obviously the easiest way to do it. Changed the cap and the leak went away for the 2 months until I just recently did a valve cover gasket job (due to finding oil on my spark plug threads during a spark plug change). During the job we thoroughly cleaned the inside of the valve cover to get the build up "slime" off which subsequently also took off a very small amount of paint that was already peeling. One of those spots was around the rim the opening where the oil fill cap sits, but I didn't worry about it since 1 layer of paint is pretty thin and I figured the gasket would compensate. It was fine for a day or 2, but now it has started leaking just a bit - same as before. So now my ideas are: 1. Put some paint or some type of high temp sealant on the rim of the valve cover fill hole 2. Buy another new oil fill cap, take the o-ring out, and use high-temp glue to bond it with the existing o-ring (aka double up) 3. Bend the prongs up a little so they form a tighter seal I feel like #1 would be the most effective solution, but have no idea what type of paint/sealant I should use #2 might work, but I would be afraid of the 2nd o-ring separating and falling down inside the valve cover #3 was a solution I found in a thread about fixing an old leaky cap, but I feel like that would "unbend" itself fairly quickly Any ideas or feedback would be much appreciated Last edited by M3MPH1S; 07-05-2019 at 07:59 AM.. |
11-06-2017, 10:26 PM | #4 |
Rep 769
11-07-2017, 06:06 AM | #5 |
Rep 10,614
Yes. Just a thought. When I had my intake manifold off to change a throttle actuator, I looked briefly inside the pcv connections and they did not look gooey or clogged but I was seeing only a small part of the system. Had 87k miles at the time. I replaced my oil cap a few gears ago. I don't get any drips but I can wipe a film of what looks like oil vapor residue away. On E36 and E39, the pvc will clog up over time. Dont know about these cars but think mine is still working fine at 9 years and 90k miles.
M3MPH1S592.00 |
11-07-2017, 07:25 AM | #6 |
Rep 713
I recently saw a pic of a '13 for sale and it had a different oil cap than my 08. Wondering now if it was an aftermarket cap trying to fix the leak or they actually changed the design...
11-07-2017, 07:58 AM | #7 | |
Rep 769
11-07-2017, 08:17 AM | #8 |
Rep 10,614
I think if there is an issue with the pvc, the issue would be located somewhere else in the pvc system, but I have not I inspected the rest. And there may be no issue.
11-11-2017, 09:16 AM | #9 |
Rep 876
I tried 2 different versions spec'd exactly for the M3 and both leaked. Finally when I tried the 3rd time with the Mini version, no leaks. The mini part is: 11128619360.
Prior to the 3rd cap, I tried using a sealant and that didn't work either. |
M3MPH1S592.00 |
11-11-2017, 11:05 AM | #10 | |
Rep 769
11-11-2017, 07:15 PM | #11 |
Rep 876
Yeah, that looks just like it. I got mine from: https://www.fcpeuro.com/products/min...er-11128619359 |
11-11-2017, 07:20 PM | #12 | |
Rep 876
There have been several revisions through the years. The newest ones no longer say Castrol on them as BMW uses Shell oil now. |
///M Power-Belgium63331.00 |
11-11-2017, 07:37 PM | #13 | |
General
63331
Rep 24,659
Same 5H1T with the friggin bearings...
DrFerry6728.50 |
01-21-2018, 09:03 AM | #14 |
Rep 2,138
Drives: 2011 E92 M3
Leaking oil cap... I have it too.
I wonder if you could bend the tabs a little to increase the pressure on the gasket. Still pretty laughable that this is an issue. Go BMW Go!!
01-21-2018, 07:10 PM | #15 |
Rep 724
I had the issue and initially bent the tabs and it seemed to work. Replaced the cap with the newer version available at ECS. That worked initially, but it can leak if one does not press down when turning it. It seems that one tab doesn't catch and the side toward the center of the engine is not engaged.
It seems the magnesium is either wearing away or corroding. I'm going to replace the cover eventually. |
01-22-2018, 06:57 PM | #16 |
Rep 479
I put Hondabond sealant between the cap and gasket. No more leaks! I also have a spare updated oil cap too just in case. My car is 2009, I think 2010 and up had the updated oil cap. But Ive also heard they also tend to leak.
M3MPH1S592.00 |
01-23-2018, 08:04 AM | #17 |
Rep 769
Can you elaborate? Do you mean you took out the gasket then put hondabond in the "trench" then put the gasket back in and let it cure/dry?
01-23-2018, 08:45 AM | #18 |
Rep 1,256
Check the sealing area of the valve cover for paint chips.
My oil cap leaked until I sanded down the paint chip. Seals up just fine now.
02-07-2018, 12:57 AM | #19 | |
Rep 803
I am going to try this one out. thanks.
Beware of Jeff Oliver the fraud at Highland Expedition Outfitters (aka HEO or HEOutfitters) located in Cosby TN.
03-07-2018, 07:49 AM | #20 | |
Rep 2,362
Owners in JP have no clue and only do frequent oil changes (after track day/autocross/~3,000 km.) Some go supercharged; I hate to say it but I'm looking forward to hear that unmistakable bang from mains spinning.
Pass me if you can.
03-07-2018, 06:57 PM | #21 | |
General
63331
Rep 24,659
It's because I work already 15 + years in a Japanese company in Belgium. Yeah , actually I have ...let us say a number . But this/my number dates from 2014. The *Worldwide* failure % is much higher than people realize . My number is private ,it's because persons and Belgian/German jobs are involved in the information . So , I'm sorry Sir . And hope you can understand my situation . I'm talking from the Worldwide failures and not only from the (small) Bimmerpost failure list. Because the S65 bearing issue is Worldwide . For the moment we have +/- 137 bearing failures on Bimmerpost => http://www.m3post.com/forums/showthread.php?t=786615 Of course the Bimmerpost failure number is only small part from the *Worldwide* S65 bearing failures. Most Bimmerpost members (want to) see only the Bimmerpost failure number . But Worldwide is what matters ! The S65/S85 bearing subject is a very sensitive subject . Denial by the BMW/Dealers is everywhere in Europe and in the US as well . I know that few owners had really bad luck with only 6K miles on it . I know also that 2 owners had bearing failure twice . And for the moment they are running with their third S65 ! On the other hand , we/I can also see that S65's still run strong today with 200k + miles on it ... That's why I said often on Bimmerpost...*The S65 is actually a German lottery* 詳細に関してはどうぞお気軽にご連絡ください。
03-08-2018, 09:07 AM | #22 | |
Rep 479
[IMG]Untitled by Chamba, on Flickr[/IMG] |
M3MPH1S592.00 |
Tags |
leak, oil cap, paint, valve cover |
