  TireRack
      07-28-2022, 06:01 AM   #1
bmwm3fanatic
bmwm3fanatic's Avatar
Drives: 2011 E90 M3
18x9.5 TE37 best tire size to run?
Hey folks question for the 18x9.5 TE37 owners, what sizing tires are you running?
      07-28-2022, 10:21 AM   #2
B8bydesign
B8bydesign's Avatar
Drives: '11 BMW M3
2011 BMW M3  [10.00]
I would suggest going thru this thread: https://www.m3post.com/forums/showthread.php?t=486694
But most people run a 265/35/18 on the 18x9.5 ET22 TE37SL.
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak
Paco1M101.50
      07-28-2022, 03:45 PM   #3
Z K
Z K's Avatar
1889
Drives: E90 M3, G20 M340i
275/35/18 if you are looking to max out the tire size. 265/35 is much smaller overall wheel diameter compared to stock.
Auto Detailing Enthusiast!
Paco1M101.50
      08-03-2022, 03:07 AM   #4
alpin3m3
alpin3m3's Avatar
Drives: E92 M3 - F82 M4
The minimum and maximum recommended tire width for a 9.5 wheel is 245 and 275, with 255 and 265 being ideal.
265/35/18 square will you want the ability to rotate tires and reduce some of the understeery characteristics of the car. Wider front tires have also been known to increase tramlining although this is more dependent on tire compound and alignment.
Or you could do a 255/275 stagger or 265/275 if you like the staggered look. Even oem sizes would work but the front would look a little stretched.
Any increase or decrease in tire diameter will change the overall effective gear ratio. A smaller tire will travel less per rotation than a larger one. thus the speedometer will read slighty higher and the odometer will read slightly higher. A bigger tire would have the opposite effect. Top speed for every gear will also slightly change. Just something to keep in mind.
