03-29-2019, 09:01 AM | #1 |
Rep 47
Requesting help from ISTA experts!
Hey guys!
Okay, so where do I begin. I've been having ABS issues and emissions issues with my car. I tried swapping out the 02 sensor that was called out, some wheel speed sensors, fuses, but nothing has worked so far. I decided to try my hand at ISTA+ and the "EasyBMWTools package" that Mike put together. So I followed all instructions, have the program on my laptop (windows 10), downloaded all the files required, reg edits, and unpacked rheingold to C:\ . However, when I open ISTA+ (in admin mode), it opens normally, but after putting in VIN information then will hang on the "test vehicle" button or w/e it's called. It goes to the next page, but what I mean is it remains blank. I haven't waited more than a minute or two here, but I don't see any progress or status icons, so I assume it just is not connected to the ECU. I'm paraphrasing because I am at work, but it essentially says something like "Can not identify vehicle, try again." I Bought a KDCAN cable that was decently rated on amazon. When I plug it into my OBDII, it shows an activity light on the serial end of cable. So I am unsure if it:
Can anyone help me out? I would really like to try and solve this ABS issue this weekend. Also, I am in South Maryland if anyone is close and wants to help in person |
03-29-2019, 09:57 PM | #2 |
Derbo Tuning
3609
Rep 3,022
Check your USB COM port settings. It should have latency of 1ms and the COM port match the one in EDIABIAS.
IG:ruhrohz_m3
04-01-2019, 06:58 AM | #3 |
Rep 47
04-01-2019, 08:15 AM | #4 |
Derbo Tuning
3609
Rep 3,022
What does your settings in ista look like?
IG:ruhrohz_m3
04-02-2019, 10:35 PM | #5 |
mTekMods
2142
Rep 2,901
Click the wrench in ista make sure it’s using the EDIABAS settings.
04-08-2019, 11:25 AM | #6 |
Rep 134
Make sure on ediabas hardware setting, you choose the transfer rate of 500kbps CAN instead of just usual 100kbps.
Let me know if it works, goodluck T
Instagram: @tafikhulafaa & @88tuning.id
04-10-2019, 06:25 AM | #7 |
Rep 47
04-10-2019, 06:26 AM | #8 |
Rep 47
Tags |
diagnostic, help a noob, ista, ista-d |
