07-23-2018, 08:58 PM | #1 |
Rep 46
M3 World Experience
Hi everyone,
Just wanted to make a quick shout out to Dave at M3 World. I have just recently fitted a set of M3 World test pipes to my e92 M3 which is joined to a M Performance Inconel exhaust with the BPM Stage2 Tune+burble and DCT GTS Tune. Through out the whole process Dave was fantastic. Taking the time to answer all my questions and to then to also assist in loading the actual tunes on to the car. Dave was extremely helpful and always willing to assist with anything I needed. Dave's knowledge on the E92 M3 platform is second to none!! Thanks again Dave the car sounds and drives amazing and will get some clips up soon! I cannot recommend Dave and M3 World highly enough! |
07-24-2018, 07:31 AM | #5 | |
Rep 104
07-25-2018, 02:08 AM | #6 |
Incognito
119
Rep 566
Test pipes replace primary cats, secondary remain.
I have a similar setup to this (primary removed, BMW Perf rear ) and it sounds awesome, not too loud normal driving and screams like a banshee when its opened up. very exotic. |
07-25-2018, 06:15 AM | #7 |
Rep 104
All good. I have m3 worlds ceramic coated pipes with 200 cell cats and resonators and kept the stock back box.
I know of a forum member who had test pipes put in and that lasted a day or so before some lower cell cats were whacked back in. Mrs drives it and it's not much different to stock. As you say open it up bit of a different story and not too shabby above 5000 rpm. A E90 m3 is a bit sleeper setup xpipe. But found theres a spot in the rpm where the m3 world xpipe setup with the stock rear is a bit tinny / raspy. But hands down much better than stock and throttle response is better. 3rd to 2nd blip is where its all for me. Last edited by BMWM3TS; 07-25-2018 at 06:24 AM.. |
07-25-2018, 03:14 PM | #8 |
Rep 1,464
Drives: BMW X5M Comp
07-26-2018, 08:16 PM | #9 |
Rep 46
Normal driving is just a little bit louder than stock but screams once you open it up - extremely happy with the result. The burble tune sounds pretty nuts and you can program it to run at any rev range you like. I would recommend not running it under 4,500rpm as it would be rather annoying.
08-03-2018, 02:14 AM | #10 | |
Rep 4
