01-08-2023, 10:56 AM | #1 |
Rep 8
M3 E92 best Tire Size for ESS G1 SC
Hey guys,
i ordered the G1 SC from ESS and now i'm thinking of upgrading my tires. I currently have the Michelin PSS in 245/35+265/35 on the M359 GTS wheels with 12mm spaces in the front and 10mm in the back. Additional i got a KW CS 2-way with -2,2 front and -2,0 rear camber. I'm going for the PS4S, but i'm not sure which size makes the most sense. I can't decide between the following 3 sizes: - standard size 245/35+265/35 PS4S - upgrading to 255/35+275/35 PS4S - upgrading to GTS size: 255/35+285/30 PS4S Would the GTS size be a big improvement for the grip? Or will i get fitment problems with the GTS size? |
01-18-2023, 11:28 AM | #4 |
Rep 82
It’s because you can go wider while keeping the same overall wheel diameter. The 35 sidewall is too tall once you go 285+ Also makes a huge difference coming from the stock 265 and you can break 275s on stock power levels he won’t be able to hook on a supercharger.
01-18-2023, 12:20 PM | #5 |
YNWA
1049
Rep 815
As I understand it, for straight line grip, which is what I assume you're looking for with such increased power, is helped by more contact patch which isn't increased with a wider tire (which is a bit counterintuitive) but by the tire squating (more rubber). You might want to research if a tire with a larger profile (like a 35 instead of a 30) would help your situation.
Lowering tire pressure a few PSI will give you more grip I believe. Edit: Better (lower tread wear) tires will give you more grip too ofc. I'd rather run 245/265 PS4S than 255/285 Hankook v12s. And I think lower profile (like 30 with the 285) requires higher pressure, so less squating, less contact patch *I think*.
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 Last edited by TboneS54; 01-18-2023 at 12:31 PM.. |
Longboarder3434.00 |
